[mapguide-users] Using X,Y from Oracle
Bruno Scott bscott at geomapgis.com
Mon Dec 10 09:46:20 EST 2007
You need to use the KingFdoClass table to be able to use x,y.
With this metadata table you can also overide lots of defaults.
Like geometry type, by the way
You can find the description of this table at www.sl-king.com.
Fdo2fdo help you create and manage this table
Bruno
Kenneth, GEOGRAF A/S wrote:
> I have tried to produce points from an Oracle database with only x and y
> data, no SDO geometry.
> Using King.Oracle these tables do not appear, using the Autodesk
> provider shows these, but does not allow for mapping with X/Y.
> I then tried to load the Oracle as an ODBC connection.
> After waiting approximately 10 minutes after pressing save, the
> FeatureSource is saved.
> After this, there are no tables listed in the FeatureSource.
> Can I fix this somehow, or is it better to convert the columns to SDO?
> Regards, Kenneth, GEOGRAF A/S
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Using-X%2CY-from-Oracle-tp14254071s16610p14254167.html
