[mapguide-users] MG 2.0 beta1 on Ubuntu 7.10 not showing map
Mange magnus.ek at boliden.com
Tue Dec 11 08:59:23 EST 2007
I've installed according to the explanation in the wiki section and also
installed the Sheboygan demo + an internal project based on SHP data.
Problem with both packages is that when viewing them in either the ajax
viewer, fusion and phpviewer the map is not rendered (see attached image). I
have checked the logs under /usr/local/mapguideopensource/server/Logs and
loading the packages
I suspect that fdo-3.3 is not working as expected. Anyone have some ideas?
Is there a way to trace or alter the errorlevel on mg?
http://www.nabble.com/file/p14274495/mapguide%2Bsheboygan%2Bwithout%2Bmap.png
Thanks,
Mange
View this message in context: http://www.nabble.com/MG-2.0-beta1-on-Ubuntu-7.10-not-showing-map-tp14274495s16610p14274495.html
