[mapguide-users] Trouble with postgis provider
ary sucaya
ary.sucaya at yahoo.com
Fri Dec 14 03:45:22 EST 2007
See, the log file, what it said? I have the same problem a couple time ago. My problem if either Postgres compatibilty version or uppercase letter on table/field. Now i use postgres 8.2.4, postgis 1.3.1 and MGOS 1.2 and so far work good..
Ary Sucaya
----- Original Message ----
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Sent: Friday, December 14, 2007 8:56:46 AM
Subject: RE: [mapguide-users] Trouble with postgis provider
I have tried using the POSGISFDO connector on windows .And it works fine to
the extend that I can connect to the database and see the tables and
columns. I have generated a map but nothing s then displayed on the screen.
Any ideas?
Anther question on this, will this Postgis connector be included into later
versions of MGOS?
Andre
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Tuesday, December 04, 2007 7:27 PM
My understanding is that the PostGIS provider looks at the
geometry_columns metadata table to determine which tables are spatially
enabled.
This provider is still in alpha/beta mode, and you are more likely to
get a knowledgeable reply on the fdo-users mailing list.
Jason
Subject: Re: [mapguide-users] Trouble with postgis provider
The problem that it skips also the new created spatial tables!!!!!!! How
could the postgis provider make the diffrence between the spatial and
non spatial tables!!!
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071214/48494802/attachment.html
