[mapguide-users] Problem with login on Map guide 1.2
Ivan Milicevic
Ivan.Milicevic at supranet.hr
Sat Dec 15 17:15:05 EST 2007
The Mapguide server mabe was shutted down because of IP change. Starting
service is in 90% key for resolving this problem.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of uXuf
Sent: Tuesday, December 11, 2007 1:04 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Problem with login on Map guide 1.2
Can you think of something that you might have done exploring it as the
possible cause?
It should work fine if everything was untouched.
uXuf
Klemen Sorcnik wrote:
> Hello,
> i have problems with login on map guide open source 1.2. When i
installed
> it worked fine, but next day i want to login again it says
Authentication
> failed.
> I havent changed anything (USER: Administrator PWD: admin).
> I had no problems with login in map guide 1.2 RC2. Can anyone help
me?
> Klemen s.
> mapguide-users mailing list
View this message in context:
http://www.nabble.com/Problem-with-login-on-Map-guide-1.2-tp14248241s166
10p14272458.html
