[mapguide-users] External user cant view web layout in web browser
uXuf
yousuf.hassan at gmail.com
Wed Dec 19 04:07:14 EST 2007
Just a thought, is PHP configured properly to be used with IIS at your end?
uXuf
mimie idris wrote:
> thanks jackie,
> Yes, I do install with IIS configuration, and the mapviewerajax is
> available under the mapguide virtual directory. It's configured for
> ASP.net but I dont know whether its 2.0 or not. For additional info, I use
> PHP.
> Jackie Ng wrote:
>> Did you install with IIS configuration? If so...
>> 1 - Is there a mapviewerajax/mapviewernet virtual directory under the
>> "mapguide" virtual directory?
>> 2 - If so, is it configured for ASP.net 2.0?
>> - Jackie
>> mimie idris wrote:
>>> Hi,
>>> I've done my develop my web and its successfully view by PC with
>>> mapguide open source installed. PC with no mapguide just can view the
>>> banner and the frame where the web layout should be viewed just display
>>> "Page Cannot Be Displayed". What I do know is, there's no need to
>>> install a plugins as I'm using AJAX. I'm using MapGuide Opensource
>>> 1.2.0, Mapguide Studio 2008, and AJAX viewer.
>>> I really appreciate if someone could explain to me what's really going
>>> on. Thank you in advance.
>>> Mimie,
>>> GeoInfo Services.
View this message in context: http://www.nabble.com/External-user-cant-view-web-layout-in-web-browser-tp14412300s16610p14413076.html
