[mapguide-users] Trusted Sites
Chris Tallman
ctallman at innomap.com
Wed Dec 19 09:04:22 EST 2007
Ok well nevermind my last email I figured out what needs to be replaced
to update the sarissa. All that did was make it so now I can't select
point features if the site is trusted or not.
However...
I've had a new development that might lead to a solution. Having that
MSXML 5.0 control enabled is a trigger however I have some other maps
that are not effected by this. So two maps setup the same using
basically the same data providers, one having the issue the other not.
The only thing I can think of that is different between the two is one
is under a secured site and the other is not. Does anyone have any
thoughts on this causing an issue?
Chris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris
Tallman
Sent: Wednesday, December 19, 2007 8:41 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Trusted Sites
Well I didn't mean to send that blank email to everyone.
I didn't update sarissa. I just downloaded, Since I've never heard of
sarissa, do I install the update on the server on will that need to be
installed on the users computers?
I'm guessing the server so this email is probably worthless but I'm
tired and lost.
Thanks, Jackie.
Chris
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Wednesday, December 19, 2007 8:34 AM
To: mapguide-users at lists.osgeo.org
Did you upgrade the version of sarissa as also specified in that ticket?
- Jackie
ctallman wrote:
> I made the change and it didn't seem to help. When the site is
> trusted the point features still cannot be selected.
> Chris
> From: mapguide-users-bounces at lists.osgeo.org
> Sent: Tuesday, December 18, 2007 5:58 PM
> Subject: Re: [mapguide-users] Trusted Sites
> I think the problem here is that the current AJAX viewer uses the
> Microsoft.XMLHTTP ActiveX object when sending off AJAX requests (if
> your browser is IE)
> More info here.
> http://trac.osgeo.org/mapguide/ticket/368
> - Jackie
> ctallman wrote:
>> I'm hoping i'm just missing something but when I add my mapguide site
>> to the trusted site list I no longer get tool tips and I can't select
>> point features. If I remove the site from the trusted list I can
>> select the feature again.
>> So I know don't make the site trusted, however we have a site that is
>> running on a https secure address, so its nice to have it in the
>> trusted list. Plus if its not in the list I get asked the following.
>> This website wants to run the following add-on: 'MSXML 5.0' from
>> 'Microsoft Corporatioin'. If you trust the website and the add-on and
>> want to allow it to run, click here...
>> So I do it reloads and I get the same thing. However if I make the
>> site trusted I don't get this. Also If I don't have this MSXML
>> enabled I don't get my pictures next to the legend labels. I see
>> question marks until I zoom in or make the map refresh. If I have
>> the
>> site trusted I don't have any of these problems I just can't select
> features.
>> So do I have something set wrong someplace does anyone else see this
>> same problem, can anyone else reproduce this? I can reproduce on my
>> system. I've tried it on more then one IE 7.0 computers.
>> I'm using AJAX
>> MGOS 1.2
>> .NET
>> IIS V6.0
>> Windows 2003
>> Chris Tallman
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Trusted-Sites-tp14401044s16610p14407685.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
http://www.nabble.com/Trusted-Sites-tp14401044s16610p14416885.html
