[mapguide-users] Generating tiles for google maps
George McLean gmclean at gorge.net
Wed Dec 19 13:30:26 EST 2007
Was the customization to make a square projection that ran from 85
degrees south to 85 degrees north?
Thanks
George
Traian Stanev wrote:
> Yes, you have to use Mercator. To make the tiles match perfectly across the whole world, you will need to use a custom Mercator rather than the default one in MapGuide (last time I did it, I had to hardcode the projection into MapGuide). I think that if you restrict yourself to a small region, you can get away with the Mercator that already exists in MapGuide and some tiny translation tweaks to make it all align perfectly.
> Traian
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
>> bounces at lists.osgeo.org] On Behalf Of George McLean
>> Sent: Wednesday, December 19, 2007 11:26 AM
>> To: MapGuide Users Mail List
>> Subject: Re: [mapguide-users] Generating tiles for google maps
>> I have been trying to get this working as well. My approach has been to
>> use data between 85 degrees north and 85 degrees south in a Mercator
>> projection since this is what I believe Google maps uses. I am still
>> not
>> sure if this is the right approach as I am still working on it.
>> To get the tiles within your bounding box, I would create the box and
>> then zoom to the corners. The tiles for that region will be created and
>> this will help you figure out the rows and columns for each corner at
>> each zoom level. Once you know the zoom levels and row/column
>> boundaries
>> you can specify these parameters in the call to the tiling engine.
>> George McLean
>> azpublic wrote:
>>> Hi,
>>> I'm looking for a way to generate custom tiles for google maps or Ms
>>> Live maps / Virtual earth using Mapguide OS.
>>> I've created my map using studio and I'm now thinking about using the
>>> Automated tiling engine from WSD to generate the tiles.
>>> My main problem is about which scale to use to have my custom tiles
>>> match with google maps tiles. What are the mapguide scales I need to
>>> use for specific google maps zoom levels?
>>> Moreover I want to generate tiles only for a specific lat/lon
>> bounding
>>> box. Is this possible using the Tiling engine?
>>> Any help appreciated !
>>> No virus found in this outgoing message.
>>> Checked by AVG Free Edition.
>>> Version: 7.5.503 / Virus Database: 269.17.4 - Release Date:
>> 16.12.2007
>>> 00:00
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> No virus found in this incoming message.
>>> Version: 7.5.503 / Virus Database: 269.17.4/1188 - Release Date:
>> 12/17/2007 2:13 PM
