[mapguide-users] WMS problems: Raster transformation is not
supported
Jose Manuel C G
gis at mapas-sll.com
Fri Dec 21 06:54:10 EST 2007
I thing the problem is this:
http://www.nabble.com/FDO3-3A--3A-It-is-not-appropriate-to-use-the-first-CRS-as-default-SC-when-multiple-CRS-codes-are-provided.-to8935585s18162.html#a8935585
The FDO provider use the first CRS, and I can't change it.
Jose Manuel C G wrote:
> I thought I could overwrite the coord. with the bbox. The wms layer
> support 4326. How can I tell to it that take the coord. system 4326, and
> not 23030?
> Update: I changed EPSG in the file OgcWmsService.config.awd with 23030,
> and now show the next in the log:
> The coordinate system (EPSG:23030) of layer wms/Layers/wms_Catastro cannot
> be different than the coordinate system (EPSG:23030) of the map.
> o_O
> Please help me. Maybe it's a bug.
> mates wrote:
>> The coordinate system is different.You must set the coordinate system of
>> the layer to be the same as the map.
View this message in context: http://www.nabble.com/WMS-problems%3A-Raster-transformation-is-not-supported-tp14440446s16610p14454317.html
