[mapguide-users] MGE/MGOS 1.2 on .NET 3.5/ASP.NET 3.5
Jackie Ng
jackie.ng at aecsystems.com.au
Fri Dec 21 07:16:23 EST 2007
I think ASP.net, and .net framework 3.5 in general, is deceptive in its
versioning.
Though there is new language features and class libraries, it uses the same
v2.0 CLR (ie. your 3.5 code still compiles to v2.0 IL bytecode)
Also when you install the v3.5 runtime, like v3.0 it will also install the
v2.0 runtime if you don't have it already installed.
...which probably explains why there is no "3.5" version in my IIS asp.net
tab, and why the v3.5 redistributable package is 200MB!
Confused yet? :-D
- Jackie
Maksim Sestic wrote:
> Does it mean that MGOS runs on .NET 3.5 only, there's no .NET 2.0/3.5
> installed side by side? If so, that's a great news then. Thanks Jackie.
> Jackie Ng wrote:
>> I installed VWD Express 2008 on a test machine w/ MGOS 1.2.0, created a
>> new ASP.net web site with references to .net 3.5 libraries and MapGuide
>> API in the mapguide www root.
>> I put some code to initialize the web tier and create a session, and to
>> load the Sheboygan web layout.
>> No problems whatsoever.
>> - Jackie
>>> Hi all,
>>> Does anybody knows if .NET 3.5/ASP.NET 3.5 affects existing MGE/MGOS
>>> 1.2.0 installation, are there any known incosistencies, possible clashes
>>> with IIS, etc?
>>> Regards,
>>> Maksim Sestic
View this message in context: http://www.nabble.com/MGE-MGOS-1.2-on-.NET-3.5-ASP.NET-3.5-tp14415817s16610p14454417.html
