[mapguide-users] FW: Problems while labeling polylines
Maksim Sestic
max at geoinova.com
Mon Dec 31 09:26:41 EST 2007
Traian, it's been bugging me for a while too since I remember one of your
previous post when you explained how composite layers should behave on
endcaps. I'm using managed feature source (MS SQL Server) if it's of any
importance, along with custom projection (WKT defined in feature source
match the one in MG Map, reprojection to LL works fine on both WMS and WFS).
I presume you're using certain fuzz factor to determine if network topology
being candidate for stitching is properly noded? Oh, this little quirk made
me code my own AJAX-based tree view :-)
Haven't had opportunity to check how latest MGOS works, but MGE 2008 won't
stitch them correctly.
Regards,
Maksim Sestic
Traian Stanev wrote:
> Yes, that's what it looks like without the code that detects the composite
> line style. The code has been there for a long time (since release 1 in
> both open source and MGE) so I am not sure why it is not working in your
> case. Using two layers is equivalent functionality though, even in terms
> of performance. I'll check to make sure the code is still working in the
> latest build.
View this message in context: http://www.nabble.com/FW%3A-Problems-while-labeling-polylines-tp14525210s16610p14558035.html
