[mapguide-users] King Oracle Provider Version 0.5.1
Webo vedad at sl-king.com
Thu Feb 1 03:27:24 EST 2007
Which Oracle Client do you use? OC 10.2 is required for KingOracle. Read this
file (if you didn't):
http://www.sl-king.com/fdooracle/download/README.txt
Vedad
Joel Carranza wrote:
> I suspect I found the problem. The problem only occurs on layers using
> the Oracle 9.2 instance. Our 10g instance works as expected.
> Joel
> Webo wrote:
>> Hi Joel,
>> I'm using King.Oracle provider 0.5.1 and the MGOS 1.1.0 without any
>> problems. I made SQL trace and found that this provider uses spatial
>> predicate SDO_ANYINTERACT.
>> I also upgraded MGOS 1.0.1 with this one (1.1.0) which uses FDO 3.2 and
>> it
>> works same for me.
>> Vedad
>>> Yes. I got a squeaky clean and new version of everything. No problems
>>> with layer setup or anything like that. However, when I go and try and
>>> view the map.... Everything just tanks. Oracle logs show that there is
>>> no spatial predicate on table
>>> Andy Morsell wrote:
>>>> Did you get the latest version of the provider (version 0.5.1) which is
>>>> based on FDO 3.2 which is what MGOS 1.1.0 is now using?
>>>> Andy
>>>> -----Original Message-----
>>>> From: mapguide-users-bounces at lists.osgeo.org
>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Joel
>>>> Carranza
>>>> Sent: Tuesday, January 30, 2007 5:08 PM
>>>> To: MapGuide Users Mail List
>>>> Subject: [mapguide-users] King Oracle Provider Version 0.5.1
>>>> I have upgraded to Mapguide 1.1 and found that my King Oracle Provider
>>>> is
>>>> no
>>>> longer working properly. It does not appear to be applying a spatial
>>>> predicate on map requests, and thus quickly bog down with the volume of
>>>> data
>>>> returned. Anyone experinced similair problems? Am I missing something?
>>>> -Joel
>>>> jec at gatekeeper.com
>>>> Gatekeeper Systems
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/King-Oracle-Provider-Version-0.5.1-tf3146099s16610.html#a8744644
