[mapguide-users] Gdal raster
Martin Fafard
martin.fafard at geoprojection.com
Thu Feb 1 07:31:37 EST 2007
I still can't see anything. I create a new map with the extent of the
ecw but nothing in the preview. With the Autodesk.Raster.3.0, I changed
the RGB to 2 (instead of 1) the be able to see my ecw. With Gdal, the
configuration file is empty.
Another weird thing is the test connection: the first time is ok, I go
to preview and when I do another test connection I have:
"Resource was not found:
Session:94dacfa0-ffff-ffff-8000-0013cefa5f10_fr//FeatureSourceEditorsScratch/SessionVersion4.FeatureSource"
At the end, Version4 increase to 5 when I clic again the test connection.
And finally, I connect my ecw from an "ECW" folder. After the test
connection error, my ecw is in the Repositories Library...!
Martin
Frank Warmerdam a écrit :
> Martin Fafard wrote:
>> Hi
>> Gdal raster provider doesn't see my ecw coordinates (i'm guessing:
>> test connection is ok but I don't see anything)... Autodesk.Raster yes.
>> Any ideas?
> Martin,
> It is a known issue that the GDAL based provider does not provide the
> dataset extents back in a way that studio can use to initialize the
> layer extents. You need to enter the extents manually.
> I hope to resolve this once I know how.
> Best regards,
