[mapguide-users] MapGuide 1.0.2 memory leak?
Ing. Cristian Galdini
cristian.galdini at dek.it
Thu Feb 1 12:12:27 EST 2007
I have had the same problem from 1.0 version to 1.1.0,
with apache or IIS , php or .net or java,
i am not never resolve it ,
and nobody has never considered this problem.
Hi
cristian
Martin Fafard wrote:
> FDO 3.2 improve sdf and shp better than 3.0? Could it be a fastcgi
> problem? I have the same problem: very slom after 5 minutes (10 zoom
> or pan) (bundle Apache is installed).
> Martin Fafard
> Zak James a écrit :
>> Julien,
>> I'm not sure we saw that kind of memory leak, but we weren't hitting
>> 1.0.2 that hard. The 1.1.0 release is definitely worth upgrading to if
>> for no other reason than it uses fdo 3.2 which includes new and
>> improved providers.
>> zak
>> On 1/27/07, Julien-Samuel Lacroix <jlacroix at mapgears.com> wrote:
>>> Hi,
>>> We got a MapGuide 1.0.2 installation running under Apache on a Windows
>>> 2003 server that got some memory problem. The application is using the
>>> ajax viewer. It is live and running well normally. But after a day or
>>> two, the application becomes slow and a simple zoom-in uses 100% of the
>>> CPU and it takes a while to redraw the map.
>>> Does anybody encounter a simmilar behavior?
>>> Is there any bug fixes in 1.1.0 that may worth an upgrade to 1.1.0?
>>> Thanks
>>> Julien
>>> Mapgears
>>> http://www.mapgears.com/
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
