[mapguide-users] set and zoom to selection
Knight, Gregory
Gregory.Knight.bra at cityofboston.gov
Mon Feb 5 10:53:22 EST 2007
I added the code to save the selection after doing the AddFeature. Im
still getting an 'empty' Xml selection.
If I convert the selection to a string, and output that to the task
pane, its comes back as "OSGeo.MapGuide.MgSelection". If I convert the
selection to Xml, it comes back empty.
What am I doing wrong here?
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy
Morsell
Sent: Thursday, February 01, 2007 5:30 PM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] set and zoom to selection
After this:
selection.AddFeatures(layer, featureReader, 0);
Try adding this:
selection.Save(resourceService, mapName);
(note that your resourceService and mapName variable names may be
different)
Andy
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Knight,
Gregory
Sent: Thursday, February 01, 2007 2:02 PM
To: MapGuide Users Mail List
Me again... Im trying to work through some of the PHP examples and
convert them to C#... I not doing a very good job... but Im making
some progress...
I have a feature source - to which Ive applied a basic filter. I am
able to read feature geometry and attributes from my featureReader...
now id like to convert that filtered feature to a selection... I think
there is a problem with the last four lines in the code below...
because, if I write the selectionXml variable to the task pane, it is
empty.
Any idea what Im doing wrong here?
// create a filter to select the specified parcel
String filter = "PID_LONG LIKE '%" + parcelID + "%'";
MgResourceIdentifier featureResId = new
MgResourceIdentifier("Library://BRA/Data/Bos_Parcels_06.FeatureSource");
MgFeatureQueryOptions queryOptions = new
MgFeatureQueryOptions();
queryOptions.SetFilter(filter);
// get the parcel feature from the feature source
MgAgfReaderWriter geometryReaderWriter = new
MgAgfReaderWriter();
MgFeatureReader featureReader =
featureService.SelectFeatures(featureResId, "Bos_Parcels_06",
queryOptions);
featureReader.ReadNext();
// get the parcel geometry
MgByteReader byteReader =
featureReader.GetGeometry("Geometry");
MgGeometry geometry = geometryReaderWriter.Read(byteReader);
MgPoint point = geometry.GetCentroid();
double x = point.GetCoordinate().GetX();
double y = point.GetCoordinate().GetY();
// create a selection, save the selection as XML
MgLayerBase layer =
map.GetLayers().GetItem("Bos_Parcels_06");
MgSelection selection = new MgSelection(map);
String selectionXml = selection.ToXml();
Gregory
Sent: Thursday, February 01, 2007 12:07 PM
Subject: [mapguide-users] set and zoom to selection
I have an application that allows a user to get parcel info for a given
parcel id. The application flow is much like many of the available
developer samples:
- Get parcel id from user
- Return link to parcel
- User clicks on link to zoom to parcel
- User can then select parcel to display parcel attributes
This works, but I think there is much more user interaction here than
necessary. Once I have the parcel id from the user (and I know its
valid), Id like to automatically zoom to that parcel and display the
relevant parcel data in the task pane. Im a little stumped on how I
might do this, as the examples that illustrate setting active selection,
zooming to active selection, etc - all rely on using page load events /
javascript, XML selection sets, etc - again, all more user interaction
than I'd like.
I'm assuming I can do this with one page (as opposed to 2 or 3) via the
web api - but I cant find any examples. Can someone point me in the
right direction here?
Many thanks,
Greg
The substance of this message, including any attachments, may be
confidential, legally
privileged and/or exempt from disclosure pursuant to Massachusetts
law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and
delete the material from any computer.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070205/cbed9e76/attachment-0001.html
