[mapguide-users] WebStudio bug...
Paul Spencer
pspencer at dmsolutions.ca
Mon Feb 5 19:14:13 EST 2007
Andrew,
you are probably correct. Thinking about this, I suspect that we did
not url encode the password field and so these characters, and
probably some others (&, =, %, #, ?), would cause problems. If you
don't hear that this is fixed in the next little while, please feel
free to ping me - especially after the bug tracker is up and running.
Cheers
Paul
On 5-Feb-07, at 3:02 PM, Andrew DeMerchant wrote:
> WebStudio has a bug that prevents me from logging in (unless I
> change my password)......Basically, the WebStudio login script must
> not be encoding / decoding my password properly. My password for my
> admin account has some slightly unusual chars, though they're
> perfectly acceptable....when I try to login using that password, I
> can't get in. If I log is as Anonymous, then it works no problem. I
> suspect that the chars that are causing the problems could be any
> one of these: "/", ";", or ":"
> Andrew
> <logo.gif>
> Andrew DeMerchant
> Computer Technologist
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> GEMTEC Limited
> 191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> <logo.gif>
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
