[mapguide-users] How to select expression with the FDOproviderforSDF
Bruno Scott Bruno at geomapgis.com
Wed Feb 7 05:43:10 EST 2007
Thanks a lot Greg
It works fine.
With only one detail
queryPropertyName = FdoComputedIdentifier::Create(L"AMOUNT", L"AREA * LAND_VALUE");
does not work directly
I used
queryPropertyName = FdoComputedIdentifier::Create(L"AMOUNT", FdoExpression::Parse(L"AREA * LAND_VALUE"));
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: mardi 6 février 2007 19:32
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] How to select expression with the FDOproviderforSDF
Actually, after consulting with other team members, you can achieve the expected results using the FdoISelect command.
You need to use a computed identifier; try replace the "FdoIdentifier::Create("AREA * LAND_VALUE");" with FdoComputedIdentifier::Create(L"AMOUNT",L"AREA * LAND_VALUE");
  FdoPtr<FdoISelect>        sampleSelect;
  FdoPtr<FdoIFeatureReader> sampleFeatureReader;
  FdoPtr<FdoIdentifier>     queryPropertyName;
  sampleSelect = (FdoISelect*)m_connection->CreateCommand(FdoCommandType_Select);
  sampleSelect->SetFeatureClassName("Parcels");
  FdoPtr<FdoIdentifierCollection> propertyCollection = sampleSelect->GetPropertyNames();
propertyCollection->Add(queryPropertyName);
  sampleFeatureReader = sampleSelect->Execute();
  while (sampleFeatureReader->ReadNext() )
      printf("(AREA * LAND_VALUE) = %ls\n", sampleFeatureReader->GetString(L"AMOUNT") );
Sent: Tuesday, February 06, 2007 10:09 AM
Subject: RE: [mapguide-users] How to select expression with the FDO providerforSDF
I believe you need to use the FDO SelectAggregates command as generally outlined below....
FdoPtr<FdoIDataReader> myDataReader;
FdoPtr<FdoISelectAggregates> selCmdAggreg;
selCmdAggreg = (FdoISelectAggregates*)mConnection->CreateCommand( FdoCommandType_SelectAggregates );
selCmdAggreg->SetFeatureClassName(L"ClassA");
FdoPtr<FdoComputedIdentifier> cmpId = (FdoComputedIdentifier*)FdoExpression::Parse(L"(PropertyA*PropertyB) AS FunctionA");
FdoPtr<FdoIdentifierCollection> idCol = selCmdAggreg->GetPropertyNames();
idCol->Add( cmpId );
myDataReader = selCmdAggreg->Execute();
while ( myDataReader->ReadNext() )
    printf("(PropertyA*PropertyB) = %ls\n", myDataReader->GetString(L"FunctionA") );
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Bruno Scott
Sent: Tuesday, February 06, 2007 5:50 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] How to select expression with the FDO provider forSDF
I'm trying to select expression using the FDO provider for SDF but it always
return me errors
This is my sample code
  queryPropertyName = FdoIdentifier::Create("AREA * LAND_VALUE");
What am i doing wrong?
Thanks
Bruno Scott
View this message in context: http://www.nabble.com/How-to-select-expression-with-the-FDO-provider-for-SDF-tf3179976s16610.html#a8823998
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070207/41bd3a01/attachment-0001.html
