[mapguide-users] RE: MapGuide service would not start
Dave Wilson
dave.wilson at autodesk.com
Wed Feb 7 13:56:34 EST 2007
Can you give us some details about the box you are running your VM on,
speed, ram etc?
Are the VM files saved on a partition separate from your OS?
How much memory have you allocated to the VM and how much ram does the
base system have? Can we assume the VM isn't swapping to disk to start
itself up because there is not enough ram available?
We use VM's all the time and generally don't have a problem with the
service starting regardless of Windows 2000, 2003 or XP.
Regards,
Dave
_____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of ross s
Sent: Wednesday, February 07, 2007 11:51 AM
To: MapGuide Users Mail List
Cc: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] RE: MapGuide service would not start
Hi
Most of my Virtual Machines i run with the base OS (with the standard
services enables) not other software installed, i try to keep these
machines lean for performance and testing purposed.
ross
----- Original Message -----
Date: Wednesday, February 7, 2007 10:28 am
Subject: [mapguide-users] RE: MapGuide service would not start
> Do you have any services running on your machine that could be slowing
> down the startup of the MapGuide Service? As I recall, the
> services are
> started in alphabetical order, so one thing you could try is to change
> the name of the service, which will affect the start order of the
> services in Windows. The default name for the service is "MapGuide
> Server". You can specify your own name when you install the
> service at
> the command line using "mgserver /install <Name>". If you give it a
> name such as "Aaa Mapguide Server" perhaps the machine can try and
> startit before it starts some other resource-consuming service.
> Ronnie
> -----Original Message-----
> Date: Tue, 6 Feb 2007 13:04:13 +0900 (JST)
> From: Hidekazu Shimaji <hshimaji at ybb.ne.jp>
> Subject: [mapguide-users] MapGuide service would not start
> automatically
> To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> Message-ID: <20070206040413.36414.qmail at web10009.mail.tnz.yahoo.co.jp>
> Content-Type: text/plain; charset=iso-2022-jp
> Hello,
> I have trouble with MapGuide Open Source 1.1.0.(not RC1)
> MapGuide Server service would not start automatically in starting
> windows XP.
> Only an event log message is left:
> 7009 : Timeout (30000 milliseconds) waiting for the MapGuide Server
> service to connect.
> (Originally this message is written in Japanese.)
> I can start this service manually.
> Does anyone know something about it?
> Thanks.
> Hidekazu Shimaji
> mapguide-users mailing list
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070207/0f0100a2/attachment-0001.html
