[mapguide-users] New to Map Guide
Faizan Tayyab Faizan.Tayyab at ordnancesurvey.co.uk
Thu Feb 8 13:05:03 EST 2007
Thanks it worked.
I have followed the guide for Autodesk Studio. I wanted to what is the
best resource/tutorial for learning to develop custom web application
using MapGuide and later on integrating google maps. Is there any other
resource other then the Developer guide. I am using PHP as I had
problems with installing MapGuide server extensions on XP and using IIS
for .NET. but PHP with Apache works quite well.
Any advice on how to proceed about development in MapGuide would be
helpful
Thanks in Advance
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: 08 February 2007 17:33
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] New to Map Guide
Faizan Tayyab wrote:
> Once I have a web layout created [...] how can I publish it so that
> it is visible to other users as well?
On your MapGuide server, install the sample application for your chosen
programming language and then modify the sample to point to your web
layout instead of Sheboygan.
Download samples: http://mapguide.osgeo.org/downloads.html#samples-1.1.x
Instructions for installing:
http://mapguide.osgeo.org/files/mapguide/docs/InstallMapGuideOpenSourceS
amples.pdf
For instance, in the phpviewersample directory, the ajax viewer is
launched from the "ajaxviewersample.php".  In this file you would modify
the following lines to point to your MapDefinition and WebLayout:
 $mapDefinition =
"Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition";
 $webLayout =
"Library://Samples/Sheboygan/Layouts/SheboyganPhp.WebLayout";
Jason
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
This email is only intended for the person to whom it is addressed and may contain confidential information. If you have received this email in error, please notify the sender and delete this email which must not be copied, distributed or disclosed to any other person.
Unless stated otherwise, the contents of this email are personal to the writer and do not represent the official view of Ordnance Survey. Nor can any contract be formed on Ordnance Survey's behalf via email. We reserve the right to monitor emails and attachments without prior notice.
Thank you for your cooperation.
Ordnance Survey
Romsey Road
Southampton SO16 4GU
Tel: 08456 050505
http://www.ordnancesurvey.co.uk
