[mapguide-users] Point style w/no fill causes MG server crash
Traian Stanev
traian.stanev at autodesk.com
Thu Feb 8 17:19:55 EST 2007
That's unfortunate. You could probably manually set the color to
transparent by editing the layer xml, if you really need transparent.
The crash happens when generating the legend preview image, so you could
try to remove the layer from the legend to bypass that code. I realize
that's not the best solution... if you are compiling your own MapGuide,
I could tell you what code change to make to make it work.
Traian
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kayne M.
Morvant
Sent: Thursday, February 08, 2007 4:10 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Point style w/no fill causes MG server
crash
Thanks for the tip, but the UI does not allow a transparent fill color
for
point styling.
-Kayne
At 04:03 PM 2/8/2007 -0500, you wrote:
>Yes I see where the bug is, the code assumes a non-null Fill at some
>point. Try using a transparent fill color (if the UI will let you do
>that at all) to work around.
>From: mapguide-users-bounces at lists.osgeo.org
>Morvant
>Sent: Thursday, February 08, 2007 3:52 PM
>To: mapguide-users at lists.osgeo.org
>Subject: [mapguide-users] Point style w/no fill causes MG server crash
>Hi,
>In MapGuide Studio when I style a point symbol and choose to not apply
>fill
>to the symbol, MapGuide server crashes when I attempt to preview the
>layer. I have attempted this with the square mark and circle mark
>symbols
>and get the same results. My data source is an .sdf file loaded as an
>unmanaged data resource.
>I am running MGOS 1.1 on Linux and MG Studio ver. 1.0.0.17804 (patched
>to
>connect to MGOS 1.1).
>Anyone else experience this behavior?
>thanks,
>Kayne
>_______________________________________________
>mapguide-users mailing list
>http://lists.osgeo.org/mailman/listinfo/mapguide-users
