[mapguide-users] RE: Map Tiled Perfomance
Kencana bluesky_dyx at hotmail.com
Sat Feb 10 11:04:27 EST 2007
Hi Trevor,
thanks for the reply. i have read the "MapGuide RFC 11 - Stateless Http
GETTILEIMAGE request" article.
and i notice that there is a new version of get tiled map image request. the
existing one is version 1.0.0.
so in order to use the new version, can i just change the 1.0.0 to 2.0.0? or
should i install any update?
i am sorry but can you explain on how to Implement version 2 of
GETTILEIMAGE?I felt a bit confused with the
explanation in the article.i am sorry but please don't mind.I hope you can
help me out, as i need to improve the
performance as soon as possible.
Thank you very much
Regards,
Kencana
Trevor Wekel wrote:
> Hi all,
> I'm not sure what version of MapGuide everyone is using but the
> following performance tweaks do help in the trunk code base and may help
> with the officially released streams:
> - Turn on data connection pooling and caching for all data sources
> (including SDF and SHP)
> In serverconfig.ini:
> [FeatureServiceProperties]
> CacheSize = 100 (3 x the number of layers you are serving should be
> sufficient)
> DataCacheSize = 100 ( >= number of distinct feature sources you are
> serving)
> DataConnectionPoolEnabled = 1 (turn it on)
> DataConnectionPoolExcludedProviders = none  (turn connection pooling on
> for all feature sources)
> DataConnectionPoolSize = 100 ( >= number of feature sources you are
> serving)
> When you turn connection pooling on for file based data sources, the
> files remain open so you may not be able to remove or overwrite them.
> This will affect APIs like ApplyResourcePackage.
> In trunk, a new API has been added to MgTileService which will make
> cache generation scripts easier to write.  Take a look at RFC 11.
> http://wiki.osgeo.org/index.php/MapGuide_RFC_11_-_Stateless_Http_GETTILE
> IMAGE_request
> Thanks,
> Trevor
> -----Original Message-----
> From: Kori Maleski [mailto:kmale at telus.net]
> Sent: Thursday, February 08, 2007 8:46 PM
> To: 'MapGuide Users Mail List'
> Subject: RE: [mapguide-users] Map Tiled Perfomance
> I resemble that remark. :-)
> The only way to improve performance without auto-generation is to
> manually pan around for each zoom threshold to generate the cache.
> We will be releasing a utility to do the auto-generation in the next
> month or so.  Still tweaking...
> Kori Maleski
>   _____
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
> Sent: February 8, 2007 6:57 PM
> To: MapGuide Users Mail List
> You have 37 layers each on its own base layer in the same map?
> Or you have a single base layer with 37 layers in it?
> The latter is immeasurably preferred.
> If they are already all in a single base layer, you may want to look at
> auto-generating the tiles.
> Certain folks that have already done this internally would be well
> looked upon if they released their source :)
> Jason
>   _____
> From: Kencana
> Subject: [mapguide-users] Map Tiled Perfomance
> currently i have 37 layers in the base layers. and the performance of
> the first map tiled loading will take arround 30 seconds. any idea on
> how to make it faster in the first map loading?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Map-Tiled-Perfomance-tf3197518s16610.html#a8901991
