[mapguide-users] CPLCleanupListTLS Error (Was RE: LibXerces
conflict on Ubuntu Dapper Drake?)
Jo Cook
j.cook at OXFORDARCH.CO.UK
Mon Feb 12 11:00:41 EST 2007
Hi Frank,
I tried adding the FDO version of libgdal to ldconfig (if that's the right
way of putting it- it shows up when I run ldconfig -v anyhow), and I also
tried configuring Mapguide Opensource --with-gdal=/path/to/fdo/libgdal/lib
and when I ran make again I got an error saying
"cannot find -lgdal".
A bit of googling seems to suggest that I've not done everything I need to
persuade mapguide to use this version, and that my links are not correct,
but this is pushing the limits of what I know how to do. Can I copy the
libgdal version 1.9 files into the Thirdparty directory (and
overwrite/remove the version 1.8 files)?
Thanks
Jo
Frank Warmerdam-2 wrote:
> Jo Cook wrote:
>> Hi Frank,
>> Many thanks for your response. Unfortunately my inexperience with all
>> things
>> linux means I have to go away and figure out how to do the things you've
>> suggested, but in the interim, when I did a simple "find" for instances
>> of
>> libgdal on my system I couldn't find any instances of libgdal other than
>> those related to fdo and mapguide opensource. The different versions are
>> as
>> follows:
>> /usr/local/fdo-3.2.0/lib/libgdal.so.1.9.0
>> /home/joc/mapguide-1.1.0/Oem/gdal-1.3.0/.libs/libgdal.so.1.8.0
>> /home/fdo/OpenSource_FDO/Thirdparty/GDAL1.3/linux/lib/optimized/libgdal.so.1.9.0
>> I had installed libgdal1c2a and libgdal1-dev from the ubuntu repository
>> but
>> got rid of them in case there was a conflict.
>> Hope this is useful, and thanks for your help
> Jo,
> The gdal-1.3.0 version you list might well produce the result we saw, but
> it isn't obvious to me why it would be picked up at link time. I don't
> really have any more advice ... sorry.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/LibXerces-conflict-on-Ubuntu-Dapper-Drake--tf3200598s16610.html#a8926865
