[mapguide-users] Mapguide OS login failed
Bruce Dechant
bruce.dechant at autodesk.com
Mon Feb 12 12:31:18 EST 2007
The ports used by the server are specified in the serverconfig.ini file.
There is also a webconfig.ini file used by the MapGuide web extension.
The ports specified in these 2 files must match as this is what is used
for communication between the web extension and the server.
Note: These ports are independent of Apache.
Bruce
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of schwanzy
Sent: February 12, 2007 3:54 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Mapguide OS login failed
Jose Manuel C G wrote:
> Probably the Service Mapguide Server is off line. Try to get on line.
I agree with you.
First I start apache daemon with './httpd' and I see It listening on
port 8008.
Then I start mapguide os with './mgserver.sh', but there's no output on
console, and there's no process listening on any new port.
What is the port used by 'mgserver'?
Thanks.
S.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
