[mapguide-users] DWF Viewer progress bar?
Joel Carranza jec at gatekeeper.com
Tue Feb 13 14:04:44 EST 2007
Glad we could track this down. I've simply turned off the legend for the
near future. I didn't really want the ability to turn layers off or on
anyway :) Its time to get my hands dirty and start using the server API
anyway.
I actually was able to save the returned EMapTransaction out of Fiddler
and view it as a ZIP file. It is pretty interesting to look inside and
see the different pieces, especially the relative sizes  of feature data
versus tooltip attributes along with resulting compression rates. I
think this will end up being quite useful for map tuning and debugging
in the future.
I will send details on our map setup to you in a private email shortly.
Thanks for your help
Joel
Walt Welton-Lair wrote:
> Ok, now things are making sense.  You have a lot of themed layers, and
> it's taking a few seconds to refresh the legend.  This is a full
> refresh of the legend, and it's done after applying the
> EMapTransaction if the map scale or map center has changed, which is
> the case when you pan / zoom.
> Although the data for the legend is only downloaded once at the
> beginning, the refreshing happens after each update.   So there's no
> weirdness going on.
> I don't think there's any need to use Fiddler to look at the
> EMapTransaction.  Based on what we now know I'm sure the
> EMapTransaction is small and is processed quickly (e.g. the case when
> you're zoomed in far).
> To fix this it looks like DWF Viewer needs some optimization around
> updating the legend.  E.g. only refresh it when the map scale crosses
> a scale threshhold that causes one or more layers to change its
> visibility.  Until that happens, the only way to improve performance
> right now is to reduce the amount of information in your legend.
> Maybe you don't need to display themes for some of your layers?
> I've entered a defect against DWF Viewer regarding this.  In order to
> help us reproduce this problem, can you tell me approximately:
> - how many of your layers are actually themed, and how many unthemed?
> - how many themes per layer do you have, on average
> - how many layer groups are you using?
> I'll then include this information in the defect.
> Thanks,
> Walt
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Joel
> Carranza
> *Sent:* Monday, February 12, 2007 11:10 PM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] DWF Viewer progress bar?
> Walt,
> 1) I don't follow this question
> 2) No attribute data is available.
> 3) 67-50 map layers, all themed with varying levels of complexity
> (Most complex layer has 25 themes). Some are organized into groups,
> others are not.
> 4) No custom processing, this is just our map "out of the box"
> I am pretty confident that the problem here is the legend. If I turn
> off all layers in the legend and pan, it still takes 4 to 5 seconds
> (the progress bar hangs at around 50%) for the update to complete. I
> turned off legend visibility for each layer in my map, and now the map
> performance is significantly better (progress bar always just zips
> right through). Note that if i only turn off the Legend via the
> Layout, I still have bad performance.
> Very weird, especially given that as you say, the legend is downloaded
> at the beginning.
> I am going to try and use Fiddler to look at the DWF. I had no idea
> that would/might work. Will let you know how that goes.
> Joel
>> Joel,
>> This newsgroup is the right place to ask questions about DWF Viewer behavior in the context of MapGuide.
>> Regarding your DWF problem, it looks like about half the time is the server generating the update, the other half is downloading / processing of the update.  Some other questions I have:
>> - If you mouse down and pan or zoom, is the redraw performance ok?  If it's slow then that can contribute to the processing time for the update.  When graphic resources are processed the viewer does periodic redraws of the scene graph.
>> - Have you made any feature attributes available on your layers (so that selecting a feature will display the attributes in the property window)?  Attributes are separate resources in the EMapTransaction DWF.  While they're being processed the progress bar will not move, nor will you see any graphics updates.  You should only notice a pause though if you have a large number of features with attributes.  These also compress very well in the EMapTransaction.  So the progress bar will update only briefly, but then there's a lot of processing that might need to happen once it's uncompressed.
>> - How many layers are in your map?  Each visible layer that needs to be updated will add to the number of DWF resources in the update (one for primary graphics + tooltips / hyperlinks, another for any lables, and another for attributes).  Unless you have hundreds of layers I don't think this should be a problem.  In fact if all the resources are small then the progress bar should move relatively smoothly since each resource won't take long to process.
>> - Are you doing any custom server-side processing, like dynamically adding/removing/refreshing layers?  That will add to the information in the update.
>> - How many of your layers are point layers with labels?  Those add a fair amount of data in the labeling resource.
>> Other notes:
>> - Information in the legend is downloaded at the beginning, so that's not the problem.  The only other time legend info is downloaded is if you add a new layer.
>> - An easy way to test processing time per layer is to simply toggle each one off and then back on in the legend.  Only the resources for that one layer will be upated.  Maybe one of the layers will stand out...
>> - For the DWF Viewer API docs try first doing a quick search of the MapGuide newsgroups on Nabble - there's a number of threads where I've posted these.
>> - Another interesting thing to try is to capture one of te EMapTransaction updates in the server response.  I think Fiddler (http://www.fiddlertool.com) might let you do this.  You can then open the DWF using a zip utility and see the individual resources.
>> Walt
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org on behalf of Joel Carranza
>> Sent: Mon 2/12/2007 8:44 PM
>> To: MapGuide Users Mail List
>> Cc:
>> Subject: Re: [mapguide-users] DWF Viewer progress bar?
>> 	Thank you for this information Walt, this is helpful. The problem that
>> 	we are seeing is that a typical map update may take anywhere between
>> 	approx 7-12 seconds.  Half of that time is spent w/ the hourglass
>> 	showing, and half of that time is being taken up with the progress bar
>> 	displaying (sometimes no progress shown, sometimes halfway through).
>> 	I've zoomed way in before, and had the map progress bar display almost
>> 	immediately, but I still have to wait maybe 4 or 5 seconds before the
>> 	update is complete. The number of map features we are talking about here
>> 	is less than 10.
>> 	So what could be soaking up so much CPU/Bandwidth? This isn't exactly a
>> 	lightweight machine (3.4 GHZ, 1GB of RAM, the server is on another
>> 	machine but within our local network). Could it be:
>> 	- stylization? all out objects are themed with various line style and
>> 	weights
>> 	- tooltips? Most of our map features have multi-line tooltips.
>> 	- the legend? All our layers are being displayed in the legend. When
>> 	does this information come down?
>> 	I'm taking stabs in the dark here. Any hints might be useful.
>> 	Is it possible to hook into the DWF Viewer API to look at processing
>> 	times on a per layer basic?
>> 	I can't seem to find the DWF Viewer API docs? Are these available on the
>> 	web?
>> 	Final question, i promise....
>> 	Is this even the correct place to ask this question? I find myself
>> 	confused in regard to where I should post any given question,
>> 	considering the overlap between almost all the groups.
>> 	--Joel
>> 	> The progress bar measures the total download progress for the map
>> 	> update.  Here's what happens in detail:
>> 	> 1/ the DWF Viewer requests a map update from the server
>> 	>    => hourglass cursor is shown, but no progress bar yet
>> 	> 2/ the response from the server (an EMapTransaction DWF) begins
>> 	> streaming in
>> 	>    => the progress bar is turned on and starts updating
>> 	> 3/ the EMapTransaction is a compressed file containing a sequence of
>> 	> resources:
>> 	>    a descriptor, graphic resources (W2Ds), and object definition data
>> 	> (attributes)
>> 	>    => while a resource is being downloaded the progress bar updates
>> 	>    => once a resource is fully downloaded it's immediately processed
>> 	>       * the progress bar does not update during processing
>> 	>       * depending on the size of the resource it may take some time
>> 	>         to process it, e.g. a layer with dense graphical data
>> 	>    => after the resource processing completes the next resource in the
>> 	> server
>> 	>       response is read
>> 	>       * the progress bar updates some more
>> 	> As far as the dual progress indicators, those are used in the context of
>> 	> multi-page EPlot and EModel DWFs.  One of the bars indicates the
>> 	> progress for loading the current page, while the other indicates
>> 	> progress for loading the entire DWF.  EMaps don't have multiple pages,
>> 	> and so the two indicators always have the same position.
>> 	> Walt
>> 	> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Joel
>> 	> Carranza
>> 	> Sent: Tuesday, February 06, 2007 10:05 PM
>> 	> Subject: [mapguide-users] DWF Viewer progress bar?
>> 	> Perhaps this is a silly question, but here is goes:
>> 	> Does anybody know exactly how the progress bar in the DWF operates? On
>> 	> each map request, there seems to be three stages...
>> 	> 1) No progress bar (no significant CPU activity)
>> 	> 2) Progress bar appears with very tiny amount of progress (CPU starts
>> 	> working)
>> 	> 3) Progress bar updating and map updating (CPU is working)
>> 	> There are actually two different progress bars (one on top of each
>> 	> other) which are working in tandem with each other. Does anyone know
>> 	> precisely how to interpret them? The Below URL explains for a
>> 	> multi-sheet DWF.
>> 	> http://dwf.blogs.com/beyond_the_paper/2006/09/dwf_progress_ba.html
>> 	> How does one interpret them in the context of a DWF map? Specifically,
>> 	> we are wondering about the pause at stage #2. Is that when the client
>> 	> has started recieving data, recieved all data? Is the pause at stage #2
>> 	> utterly insignificant? Anybody know?
>> 	> --joel
>> 	> _______________________________________________
>> 	> mapguide-users mailing list
>> 	> mapguide-users at lists.osgeo.org
>> 	> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070213/a63116de/attachment-0001.html
