[mapguide-users] KML generating also in MGO 1.0.2 ?
Andy Morsell
amorsell at spatialgis.com
Wed Feb 14 10:35:17 EST 2007
No, support for KML was not added until after the 1.0.2 build.
Andy
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Thomas Grosser
Sent: Wednesday, February 14, 2007 7:31 AM
To: MapGuide Users Mail List
Subject: [mapguide-users] KML generating also in MGO 1.0.2 ?
Does anyone know if there is any way to get an XML / KML file for Goggle
Earth out of the former version 1.0.2 ?
Mit freundlichen Grüßen
Thomas Grosser
- Geschäftsleitung -
Kom21 - Nürnberg
Großweidenmühlstraße 28
90419 Nürnberg
Tel.: 0911 - 378 33 85
Fax: 0911 - 378 33 86
Web: www.kom21.de
-----Ursprüngliche Nachricht-----
Von: mapguide-users-bounces at lists.osgeo.org
[mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von Jo Cook
Gesendet: Mittwoch, 14. Februar 2007 12:46
An: mapguide-users at lists.osgeo.org
Betreff: [mapguide-users] RE: Calling all Ubuntu users!!!
Hi Chris,
Many thanks for this. I had a lot of issues working through the various
compiles and installs, but the one that stopped me completely was in the
final install of the main package and is detailed in this discussion:
http://www.nabble.com/LibXerces-conflict-on-Ubuntu-Dapper-Drake--tf3200598s1
6610.html
The basic problem appears to be with libgdal- and the fact that there appear
to be separate versions in FDO and in the main MapGuide installs. No one is
really sure what the problem is though!
Could you go into more detail about the third party packages? All I did was
download the things I needed from the fdo site, and follow the instructions-
I didn't compile and install any of them separately, and the FDO and
ThirdParty compiles and installs went OK, after a few false starts.
I am going to have another go on a clean installation, to make sure that I
didn't mess anything up, so I will see how it goes...
Cheers
Jo
Chris Gountanis wrote:
> Are you having issues with the Apache\PHP, FDO, OEM or
> Server\Webextension install packages?
> You have to remember not to install some of those third party packages
> since they are included in the installer. It can cause some issues
> until the MapGuide code and installer files get updated. The
> setenvironment.sh shell file is huge. There is also 2 fixes to allow
> compilation of SHP, ODBC and MySQL FDO drivers. I got everything
> working pretty good on Gentoo on a base (bare bones) system with
> minimal extras. Join Freenode IRC Server, channels #mapguide, #gentoo
and/or #Ubuntu for questions.
> Here is a list of what I needed for Gentoo (??? means not sure if I
> needed
> yet):
> The reason why I am not sure on the ??? xalan and curl are included in
> the Third Party install for included reasons and JDK may only be
> needed for TomCat installations. If you are going full PHP no need for
TomCat.
> emerge jpeg
> emerge libxml2
> emerge unixODBC
> emerge dev-db/mysql
> emerge xalan-c ????
> emerge curl ???
> emerge sun-jdk ???
> Here is the FDO fixes:
> ****** SHP FDO CODE FIX ******
> nano
> /home/OpenSource_FDO/Providers/SHP/Src/Provider/ShpOptimizedAggregateR
> eader.h Please update ShpOptimizedAggregateReader.h so that the line
> void ShpOptimizedAggregateReader::GetInt64ForCache(FdoIdentifier
> *itemName, FdoInt64 *int32Value, bool *bIsNull ); to this void
> GetInt64ForCache( FdoIdentifier *itemName, FdoInt64 *int32Value, bool
> *bIsNull );
> ****** ODBC/MySQL FDO CODE FIX ******
> nano
> /home/OpenSource_FDO/Providers/GenericRdbms/Src/UnitTest/Common/FdoIns
> ertTest.cpp Please update FdoInsertTest.cpp so that the line return
> (FdoInt64) 9223372036854775807; to this return (FdoInt64)
> 9223372036854775807LL;
> Remember before you build FDO to edit the setenvironment.sh then run
> it to set exports and other init stuff!!!
> nano setenvironment.sh
> Locations for editing setenvironment.sh on Gentoo 2006.1:
> FDOMYSQL=/usr/include/mysql
> FDOODBC=/usr/lib
> SDEHOME=<optional if you have sde files otherwise don't touch>
> I also needed to do this for the OEM install. After you extract the files:
> ****** Fix DWF Build SH ******
> Edit build_setup.sh files with "libtoolize --copy --force" after
> "autoreconf --force" (no quotes) nano
> /home/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/bui
> ld_setup.sh
> nano
> /home/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/build/gnu/dwfemap/bui
> ld_setup.sh
> nano
> /home/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/build/gnu/dwftoolkit/
> build_setup.sh
> Soon as I get things double checked I will release a manual for modern
> Linux systems. You get many warnings but everything compiles smoothly
> in the end. The reason I choose Gentoo was because of their package
> management. Everything gets compiled with your system in mind. Which
> also means the devel files are included on eevry package... no more
> searching for SDK or Devel packages like Fedora. Other Linux distros
> drop pre-made binaries and hope for performance. I tried FC6 and had
> nothing but issues and even things like extracting took 3 times longer!
> Chris
> From: mapguide-users-bounces at lists.osgeo.org on behalf of joanne cook
> Sent: Tue 2/13/2007 3:31 AM
> To: mapguide-users at lists.osgeo.org
> Cc:
> Subject: [mapguide-users] Calling all Ubuntu users!!!
> Hi List,
> Having screeched to a halt with my installation of Mapguide Opensource
> 1.1.0 on Ubuntu 6.0.6 I am interested in hearing from anyone who has
> successfully managed to install it on that system. I won't bother you
> too much with questions about the installation- I just want to know if
> you had similar problems (with different versions of libgdal
> apparently) and if you managed to solve them.
> Many, many thanks in advance
> Jo
> Joanne Cook BSc MLitt AIFA MBCS
> Information Systems Coordinator
> Oxford Archaeology North
> This message has been scanned for viruses by BlackSpider MailControl -
> www.blackspider.com _______________________________________________
> mapguide-users mailing list
View this message in context:
http://www.nabble.com/Calling-all-Ubuntu-users%21%21%21-tf3219492s16610.html
#a8963456
