[mapguide-users] Reading data in real time?
Andrew DeMerchant andrew.demerchant at gemtec.ca
Wed Feb 14 10:48:05 EST 2007
Yep, it would be fixed geographic points with changing attributes
(likely color-coded based on 3 different ranges of numbers). I sort of
figured that MG wouldn't know enough to poll on it's own, but thought
that maybe there was some way of telling it...that maybe it had a
mechanism to do it, but that it needed some information somewhere to
actually DO it.
Andrew
Dave Wilson wrote:
> You would have to write a routine to refresh on your own. Otherwise
> MapGuide would have to have a mechanism to poll the data and see
> changes. This isn't an easy task. Unless transaction log information
> or some equivalent is exposed there is no way for MapGuide to know
> specifically what data changed and whether a refresh makes sense.
> What if a website used 5 maps pointing to 30 or so layers coming from
> a database. How would it know which ones to poll for changes? If the
> data was updating every second it would take probably a second or 2 to
> poll the database and find out a change has occurred in order to start
> a refresh.
> What kind of data are you trying to track that changes every second?
> I'm guessing it's not positioning, but some attribute changing?
> Dave
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Andrew
> DeMerchant
> *Sent:* Wednesday, February 14, 2007 6:14 AM
> *To:* MapGuide Users Mail List
> *Subject:* [mapguide-users] Reading data in real time?
> If I had a database that was constantly being updated (say every 1
> second) with data, and I had made a themed layer for that data, would
> MapGuide handle the refreshing of the layers on it's own? Would it see
> that the data has changed, and then force that layer to refresh from
> the database, or would I have to write something to refresh every few
> seconds? We're not really talking about a lot of data here, really -
> just maybe 100 geographic points, with 1 number each point (which
> would be themed based on the range that that number falls in)......
> Andrew
> 	*Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
