[mapguide-users] RE: Map Tiled Perfomance
Trevor Wekel trevor.wekel at autodesk.com
Thu Feb 15 11:41:17 EST 2007
Hi Kencana,
As Jason mentioned, this feature will be available in MapGuide 1.2.
Both the original version 1.0.0 GETTILEIMAGE and newly implemented 2.0.0
GETTILEIMAGE are supported.  In the 1.2 stream I have already updated
the Ajax viewer scripts to use the new HTTP request.  The HTTP query
string has different parameters than the original 1.0.0 request.  Here's
and example of a url for the new request:
http://localhost/mapguide/mapagent.fcgi?OPERATION=GETTILEIMAGE&VERSION=2
.0.0&MAPDEFINITION=Library://NavteqNorthAmerica/Maps/nacolorTiled.MapDef
inition&BASEMAPLAYERGROUPNAME=Base%20Layer%20Group&TILECOL=9079&TILEROW=
7440&SCALEINDEX=1
Thanks,
Trevor
-----Original Message-----
Sent: Saturday, February 10, 2007 9:04 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: Map Tiled Perfomance
Hi Trevor,
thanks for the reply. i have read the "MapGuide RFC 11 - Stateless Http
GETTILEIMAGE request" article.
and i notice that there is a new version of get tiled map image request.
the existing one is version 1.0.0.
so in order to use the new version, can i just change the 1.0.0 to
2.0.0? or should i install any update?
i am sorry but can you explain on how to Implement version 2 of
GETTILEIMAGE?I felt a bit confused with the explanation in the article.i
am sorry but please don't mind.I hope you can help me out, as i need to
improve the performance as soon as possible.
Thank you very much
Regards,
Kencana
Trevor Wekel wrote:
> Hi all,
> I'm not sure what version of MapGuide everyone is using but the
> following performance tweaks do help in the trunk code base and may
> help with the officially released streams:
> - Turn on data connection pooling and caching for all data sources
> (including SDF and SHP) In serverconfig.ini:
> [FeatureServiceProperties]
> CacheSize = 100 (3 x the number of layers you are serving should be
> sufficient)
> DataCacheSize = 100 ( >= number of distinct feature sources you are
> serving)
> DataConnectionPoolEnabled = 1 (turn it on)
> DataConnectionPoolExcludedProviders = none  (turn connection pooling
> on for all feature sources) DataConnectionPoolSize = 100 ( >= number
> of feature sources you are
> serving)
> When you turn connection pooling on for file based data sources, the
> files remain open so you may not be able to remove or overwrite them.
> This will affect APIs like ApplyResourcePackage.
> In trunk, a new API has been added to MgTileService which will make
> cache generation scripts easier to write.  Take a look at RFC 11.
> http://wiki.osgeo.org/index.php/MapGuide_RFC_11_-_Stateless_Http_GETTI
> LE
> IMAGE_request
> Thanks,
> Trevor
> From: Kori Maleski [mailto:kmale at telus.net]
> Sent: Thursday, February 08, 2007 8:46 PM
> To: 'MapGuide Users Mail List'
> Subject: RE: [mapguide-users] Map Tiled Perfomance
> I resemble that remark. :-)
> The only way to improve performance without auto-generation is to
> manually pan around for each zoom threshold to generate the cache.
> We will be releasing a utility to do the auto-generation in the next
> month or so.  Still tweaking...
> Kori Maleski
>   _____
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason
> Birch
> Sent: February 8, 2007 6:57 PM
> To: MapGuide Users Mail List
> You have 37 layers each on its own base layer in the same map?
> Or you have a single base layer with 37 layers in it?
> The latter is immeasurably preferred.
> If they are already all in a single base layer, you may want to look
> at auto-generating the tiles.
> Certain folks that have already done this internally would be well
> looked upon if they released their source :)
> Jason
>   _____
> From: Kencana
> Subject: [mapguide-users] Map Tiled Perfomance
> currently i have 37 layers in the base layers. and the performance of
> the first map tiled loading will take arround 30 seconds. any idea on
> how to make it faster in the first map loading?
> mapguide-users mailing list
View this message in context:
http://www.nabble.com/Map-Tiled-Perfomance-tf3197518s16610.html#a8901991
