[mapguide-users] Raster Layer Issues
Fri Feb 16 17:21:47 EST 2007
Gary Ellsworth wrote:
> I am using MapGuide Studio 2007 and OS 1.1 and can not get raster layers
> to work. Prior to upgrading to 1.1, I would get the following error:
> “An exception occurred in FDO Component. Unable to load the FDO
> provider: The specified procedure could not be found”. Once I installed
> the new OS 1.1, I get “Server does not support requested provider:
> Autodesk, Raster”. What did I do wrong, or how can I get this to work?
Gary,
With MapGuide OS 1.1 you no longer use the Autodesk Raster provider.  Now
you should be using the OSGeo (GDAL) raster provider.  You will likely
need to delete and recreate your data connection with this new provider.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
