[mapguide-users] RE: RE: .NET environment
Brad L bradl at mai-eng.com
Fri Feb 16 15:36:13 EST 2007
Another suggestion:
When you are setting up your project don't use the VS web server.  When you
create a web site hit the browse button and use the Local IIS option.  This
will run and debug your application with IIS instead of on the VS web
server.
I am guessing most of your problems are coming from the relative paths in
your application using the VS web server to handle mapguide requests (which
is configured in IIS and not on the VS sever).
Good luck.
Brad Leighninger
Mathews & Associates
417-869-6009
Knight, Gregory wrote:
> Understood.
> Ive confirmed your suspicion.  If I leave the port in the url and put a
> break in the first page, it hits the break and I am able to step through
> the code (on the first page).  If I remove the port from the url it
> never hits the break on the first page.
> However, I still cant get past the first page.  Once I step past the
> first page, I get 404 errors - Im not sure if this is the built in web
> server, mapguide, or a combination of both.
> In reading some other threads on the errors Im getting, Im thinking I
> might be better off with the full-blown version of VS - as opposed to
> the express version im using now.  Im going to check out the 90 day
> trial and see if I don't have better luck.
> Thanks.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Brad L
> Sent: Friday, February 16, 2007 2:01 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] RE: .NET environment
> explicit and strict are different directives.
> Another guess is that the packaged server runs on that added port and
> when
> you remove it you are now making a new request outside of your ide using
> the
> machines web server.  Try keeping the port in the url (it may not play
> well
> with mapguide) to test if you can hit any break point at all.  you may
> need
> to create a dummy page with some code in the page load event, put a
> break
> point in, set as start page and run.
> Brad Leighninger
> Mathews & Associates, Inc.
> 417-869-6009
>> I did have debugging enabled - although I didn't have the
>> strict/explicit parameters.  I added those, but it didn't seem to make
> a
>> difference.
>> Thanks for the web server tip.
>> Greg
>> Sent: Friday, February 16, 2007 1:18 PM
>> Subject: Re: [mapguide-users] .NET environment
>> check to make sure you have debugging enabled in your config file
>> <compilation debug="true" strict="false" explicit="true">
>> I don't like the packaged webserver.  If you don't want to change your
>> ide
>> settings but you would like to try it in a different web server set
> your
>> start options to:
>> "Don't open a page.  Wait for a request from an external application"
>> now you can open up a browser and call http://localhost/myapplication
>> and
>> debug
>> I use the full VS product but it should be similar in Web Developer.
>> Brad Leighninger
>> 417-869-6009
>>> Since there seem to be some .NETers listening today, I thought Id
>> throw
>>> this one out there...
>>> I use .NET/C# as my development environment.  One of the reasons I
>> chose
>>> this environment for MGOS development in the first place was the
>> Visual
>>> Web Developer IDE... things like intellisense, debugging, etc...
>>> Unfortunately I haven't been able to completely take advantage of
> this
>>> environment - particularly for debugging.
>>> First I set some breakpoints on various task pages.  Then I launch my
>>> application from the main page in debug mode from VWD.  VWD launches
>> my
>>> application in the ASP Development Server (and after I remove the
> port
>>> number that it adds), I can run my application.  If I select one of
>> the
>>> task pages where I previous set a break point, the point never gets
>> hit.
>>> VWD tells me that "The breakpoint will not be hit.  No symbols have
>> been
>>> loaded for the current document."
>>> I assume others have got past this?  If I could get past this, I
> might
>>> post less questions to the list! :)
>>> Thoughts appreciated,
>>> Greg
>>> The substance of this message, including any attachments, may be
>>> confidential, legally privileged and/or exempt from disclosure
>>> pursuant to Massachusetts law. It is intended
>>> solely for the addressee. If you received this in error, please
>>> contact the sender and delete the material from any computer.
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
>> http://www.nabble.com/.NET-environment-tf3240988s16610.html#a9009676
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
> http://www.nabble.com/.NET-environment-tf3240988s16610.html#a9010347
View this message in context: http://www.nabble.com/.NET-environment-tf3240988s16610.html#a9011916
