[mapguide-users] PostGIS selection bug?
Nichols, Mark A. markn at spicergroup.com
Mon Feb 19 10:44:03 EST 2007
I have the same problem and have not dug deep enough into the problem to fix it, however I do have the instructions.  You need to set the
PGSQL_OGR_FID configuration variable to equal the name of the ID column
of your data. I was told this was documented in the OGR Postgres page (see
http://www.gdal.org/ogr/drv_pg.html).
Please let me know if you get it and anything odd about the fix....because I still have to do it!
Mark
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Maciej Skorczewski
Sent: Monday, February 19, 2007 10:06 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] PostGIS selection bug?
my mistake
3. is a MULTILINESTRING  - so whit this type of postgis data is problem
whit selection.
Maciej Skorczewski napisał(a):
> hi all!
> did you have any problem whit selected object on map who are stored in
> PostGIS datasource?
> i use 3 direfent layers:
> 1. is a polygon - user can selected it - selected object is in blue.
> 2. is a LINESTRING - whitout problem too (like 1.)
> 3. is a LINESTRING (layers of roads) - PROBLEM - after selected  it i
> can  see all information about it (in properties pane ) but object isn't
> selected in blue. :(
> Did anybody have similar problem?
> I use:
> MG 1.1.0
> FDO 3.2.0
> PostgreSQL 8.2 + PostGIS.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
