[mapguide-users] PostGIS selection bug?
Traian Stanev traian.stanev at autodesk.com
Mon Feb 19 13:36:51 EST 2007
If the fid is called "ogc_fid", like in the first example, setting the PGSQL_OGR_FID environment variable will not make a difference for selection, since ogc_fid is the default value.
In the second example, your FID is called "gid" and so you will need to set the PGSQL_OGR_FID variable to gid to make selection work.
Personally I used shp2pgsql to do the import when testing with PostGIS. However, I had a plain ASCII file, while you have a Polish one. You may have better luck asking how to import such a file into PostGIS on a PostGIS mailing list.
Traian
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Maciej Skorczewski
Sent: Monday, February 19, 2007 1:19 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] PostGIS selection bug?
hi Mark!
Can you write your ogr2ogr command (or shp2pgsql if you use it) of import shp to postgis?
i use this command:
ogr2ogr -f postgres "PG:dbname=postgis user=postgres password=pass host=localhost port=5432"  osienazwy.shp
this command create a table:
CREATE TABLE osienazwy
   ogc_fid serial NOT NULL,
   wkb_geometry geometry,
   id double precision,
   idulicy double precision,
   ulica character(30),
   id1 double precision,
   id2 double precision,
   kier2 character(1),
   length numeric(31,15),
   idodcinka double precision,
   CONSTRAINT osienazwy_pk PRIMARY KEY (ogc_fid),
   CONSTRAINT enforce_dims_wkb_geometry CHECK (ndims(wkb_geometry) = 2),
   CONSTRAINT enforce_geotype_wkb_geometry CHECK
(geometrytype(wkb_geometry) = 'LINESTRING'::text OR wkb_geometry IS NULL),
   CONSTRAINT enforce_srid_wkb_geometry CHECK (srid(wkb_geometry) = -1)
WITHOUT OIDS;
ALTER TABLE osienazwy OWNER TO postgres;
!!!BUT!!!
i have problem whit encoding so can't load data form shp - have can i
use another encoding? (i think that table create is ok.)
i have this error
http://img89.imageshack.us/img89/3579/errorae0.jpg
when i  use shp2pgsql i get another table (whit this same shp file)
   gid serial NOT NULL,
   id bigint,
   idulicy bigint,
   ulica character varying(30),
   "pełna" character varying(100),
   id1 bigint,
   id2 bigint,
   kier2 boolean,
   length numeric,
   idodcinka bigint,
   the_geom geometry,
   CONSTRAINT osienazwy_pkey PRIMARY KEY (gid),
   CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
   CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
'MULTILINESTRING'::text OR the_geom IS NULL),
   CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = -1)
WITHOUT OIDS;
