[mapguide-users] Caching Tiles
Maciej Skorczewski
maciej.skorczewski at procad.pl
Thu Feb 22 05:41:12 EST 2007
hi!
yes i look a script/solution who clear cache in ajax title...perhaps
anyone have made it before?
now i use map whitout ajax cache - it's too slow...
in may aplication who get data form postgis data i add/del/move object
on map simply by use of webbrowser...it works fine but work whitout tile
base map (ajax cache) is veeery slow.
did you know hove - by use of PHP can i clear cache in tile base map?
Regards , maciek
Nichols, Mark A. napisał(a):
> Does anyone out there have a script to cache tiles? I'm already using
> the tiling feature of MapGuide, but I'd really, really like to cache the
> entire map by running a script. So when browsing the map, no tiles
> would need to be generated, this would have already been done with the
> script. I feel like I'm very close, but just not quite there. If
> anyone is doing this, or can advise, it would be a great help.
> Thanks in advance,
> Mark Nichols
> markn at spicergroup.com
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
