[mapguide-users] Storing WebLayout in Session Repository
Hidekazu Shimaji
hshimaji at ybb.ne.jp
Thu Feb 22 08:27:42 EST 2007
Paul's advice is a great help for me, but this means that
I cannot use the MgMap class if I want to change a map
in initially showing the map, doesn't it?
I agree with Gunter.
It is very complicated, and I also hope a method to show "Map"
as well as "MapDefinition".
Hidekazu
--- Gunter Becker <gunter.becker at CSOGIS.DE> wrote:
> So I think the steps I have to perform are:
> - Store the original MapDefinition in Session Repository (make a copy)
> - Make a reference to the users Map in Session Repository
> - loop through all the layers in the Map to get all the properties like
> for example the visibility of a layer
> - Modify the copy of the MapDefinition with this properties
> - Call AjaxViewer with stored WebLayout and the modified MapDefinition
> Does anyone agree with me?
> If so then it's a bigger job than I've first thought.
> Isn't there a method somewhere to make a new MapDefinition out of a Map?
> I have to store the original MapDefinition which was first called with the
> WebLayout into the session repository and then try to iterate through the
> layers collection of the Map to modify the
> Hidekazu Shimaji wrote:
> > Hello,
> > Not "NeulingenALK.Map" but "NeulingenALK.MapDefinition" is required for
> > the WebLayout.
> > I tried the same way of you, but it did not work.
> > I don't know why. I finally gave up using the MgMap class,
> > and used the SetResource function for setting a xml of the MapDefinition.
> > Does anybody know about it?
> > Regards,
> > Hidekazu Shimaji
> >> OK your code works for me but now I got the problem that the map isn't
> >> shown
> >> in the AjaxViewer. Instead I got hte following error message:
> >> An unclassified exception occurred. Exception occurred in method
> >> MgMap_Create__SWIG_0 at line 681 in file .\MgApi_wrap.cpp
> >> My Query to launch AjaxViewer:
http://geo19/mapguide/mapviewerajax/?SESSION=bb143bae-ffff-ffff-8000-000476dc3d5a_en&WEBLAYOUT=Session:bb143bae-ffff-ffff-8000-000476dc3d5a_en//Current.WebLayout
> >> XML representation of the WebLayout:
> >> <?xml version="1.0" encoding="utf-8" ?>
> >> <WebLayout xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> >> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> >> xsi:noNamespaceSchemaLocation="WebLayout-1.0.0.xsd">
> >> <Title>ALK Neulingen</Title>
> >> <Map>
> <ResourceId>Session:279a9b8c-0000-1000-8000-000476dc3d5a_en//NeulingenALK.Map</ResourceId>
> >> <HyperlinkTarget>TaskPane</HyperlinkTarget>
> >> </Map>
> >> Must the <ResourceId> be of Type "MapDefinition" or is "Map" also OK??
> >> To make things clear:
> >> My intention is to store the WebLayout into the session repository to
> >> give
> >> the user the ability to leave the AjaxViewer and go to another webpage of
> >> my
> >> application and then return to the AjaxViewer. All of the changes he had
> >> done before leaving the map (changing colors, adding layers, ..) should
> >> be
> >> avbailable after loading WebLayout stored in session.
> >> Is that the right way to this ??
> >> > Hello,
> >> > I don't think the ResourceHeader is the cause.
> >> > You have to set the content of xmlWebLayout to byteArray.
> >> > How about do like this:
> >> > --- the code start
> >> > //save the xml to MemoryStream
> >> > System.IO.MemoryStream stream = new System.IO.MemoryStream();
> >> > xmlWebLayout.Save(stream);
> >> > // get byte array from the MemoryStream
> >> > byte[] byteArray = stream.ToArray();
> >> > //convert byte array to string without the first byte(BOM)
> >> > string outerXml = System.Text.Encoding.UTF8.GetString(byteArray, 1,
> >> > byteArray.Length - 1);
> >> > // convert string to byte array with the utf-8 encoding
> >> > byteArray = System.Text.Encoding.UTF8.GetBytes(outerXml);
> >> > // store the WebLayout in Session-Repository
> >> > MgByteSource byteSource = new MgByteSource(byteArray,
> >> > byteArray.Length);
> >> > byteSource.MimeType = MgMimeType.Xml;
> >> > MgResourceIdentifier userWebLayoutId = new
> >> > MgResourceIdentifier("Session:" + sessionId + @"//Current." +
> >> > MgResourceType.WebLayout);
> >> > resourceService.SetResource(userWebLayoutId, byteSource.GetReader(),
> >> > null);
> >> > --- the code end
> >> View this message in context:
> http://www.nabble.com/Storing-WebLayout-in-Session-Repository-tf3265925s16610.html#a9096652
> >> Sent from the MapGuide Users mailing list archive at Nabble.com.
> >> _______________________________________________
> >> mapguide-users mailing list
> >> mapguide-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Storing-WebLayout-in-Session-Repository-tf3265925s16610.html#a9098651
