[mapguide-users] Problem with OS Geo FDO Provider for Raster
- UPDATE
Frank Warmerdam
warmerdam at pobox.com
Thu Feb 22 16:22:31 EST 2007
Jeff_Hobbs at sjwater.com wrote:
> All,
> If anybody is curious, when I translated the image documented below to ECW
> using the free compressor, it came up just fine in MGOS. Apparently the
> Raster FDO has large problems with my TIFFs. Not sure if it's the tiling,
> overviews/pyramids, or maybe even the compression.
> Anyhow, just wanted to pass along the information.
Jeff,
GeoTIFF is my workhorse format for GDAL so I'm surprised you are having
a problem with geotiffs. Perhaps there is something special about your
image(s)? If you could put one somewhere I could grab it, I'll like to
take a closer look.
Generally speaking GeoTIFFs should be a good format for use with the
FDO GDAL raster provider.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
