[mapguide-users] Error: Unable to Make Permanent Changes to Map
Hidekazu Shimaji hshimaji at ybb.ne.jp
Sat Feb 24 21:32:30 EST 2007
Hello,
You also have to use the SetResource function with the MapDefinition, which you are going to
change, to the Library Repository.  The MapDefinition is a template for a run-time map, so
you have to change it to use permanently.
Recently we discussed a similar topic.  Please see the following link:
Storing WebLayout in Session Repository
http://www.nabble.com/Storing-WebLayout-in-Session-Repository-tf3265925s16610.html#a9078585
Regards,
Hidekazu
--- Jim O'Leary <joleary.public at gmail.com> wrote:
> Has there been an answer to this question? Can you save a runtime map to the
> repository?
> I have a map to which a user can add a new layer to a given layer group
> using the browser. My program can save the new layer to the repository using
> SetResource(), and can add it to the given layer group in the runtime map.
> Is there a way to programmatically save the runtime map with the new layer
> to the repository?
> Thanks
> Robert Bray-2 wrote:
> > Stephen,
> > There are two distinctly different object types at play here and I
> > suspect you might be confusing them. MapGuide Studio creates what we
> > refer to as a MapDefintion. It is defined by an XML document and
> > primarily contains a coordinate system, extent, background color, and
> > layer and group lists.
> > The MgMap object represents something slightly different.  MgMap
> > represents an instance or run time representation of a MapDefinition.
> > Each client through the viewer has it's own copy of an MgMap that is
> > usually stored in a session. I'll have to check, but I am not sure an
> > MgMap can be saved to the Library repository (that is the software may
> > prevent them from being saved in Library://). Like I said I'll need to
> > check on that.
> > Assuming it is allowed, the problem below may be because you are trying
> > to save an MgMap using a resource identifier with type 'MapDefinition'.
> > Before you go any further however, you should think about whether you
> > are really trying to create an MgMap or a MapDefinition.
> > Hope this helps...
> > Bob
> > Stephen Park wrote:
> >> I am unable to save a map permanently to the repository when the map has
> >> been opened via the MgMap.Create(.) API. I have seen 2 or 3 back-posts
> >> about
> >> this issue but no resolution. Could use some insite.
> >> Win2k3 Server
> >> MGOS 1.0.1
> >> MapGuideDotNetApi
> >> Repro:
> >> Open an  existing map via MgMap.Create(.) API
> >> 	//Resource Id is of form Library://./MyMap.MapDefinition
> >> Add layer created previously via Studio 2K7 R1 to the map
> >> 	MgMap.GetLayers().Add(newLayer);
> >> Save the Map back to the repository:
> >> 	MgMap.Save(_resourceService, resourceId);
> >> 		**Exception Here**
> >> If I use the .Save method that accepts a single argument (resource
> >> service)
> >> I get a null reference exception. Adding the same layer to the same map
> >> via
> >> MapGuide Studio works correctly. Any hints?
> >> Exception Information:
> >> OSGeo.MapGuide.MgXmlParserException: An exception occurred in the XML
> >> parser.
> >> - MgResourceServiceHandler.ProcessOperation line 80 file
> >> c:\build_tux_area\mgdev_opensource\server\src\services\resource\ResourceServ
> >> iceHandler.cpp
> >> - MgOpSetResource.Execute line 109 file
> >> c:\build_tux_area\mgdev_opensource\server\src\services\resource\OpSetResourc
> >> e.cpp
> >> - MgServerResourceService.SetResource line 712 file
> >> c:\build_tux_area\mgdev_opensource\server\src\services\resource\ServerResour
> >> ceService.cpp
> >> - MgRepositoryManager.SetResource line 867 file
> >> c:\build_tux_area\mgdev_opensource\server\src\services\resource\RepositoryMa
> >> nager.cpp
> >> - MgRepositoryManager.UpdateResource line 1004 file
> >> nager.cpp
> >> - MgResourceDefinitionManager.UpdateResource line 261 file
> >> c:\build_tux_area\mgdev_opensource\server\src\services\resource\ResourceDefi
> >> nitionManager.cpp
> >> - MgResourceContentManager.UpdateDocument line 647 file
> >> c:\build_tux_area\mgdev_opensource\server\src\services\resource\ResourceCont
> >> entManager.cpp
> >> - MgResourceDefinitionManager.UpdateDocument line 601 file
> >> nitionManager.cpp
> >> - MgResourceDefinitionManager.ValidateDocument line 429 file
> >> nitionManager.cpp
> >> - MgResourceContentManager.ValidateDocument line 536 file
> >> entManager.cpp
> >> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> >> For additional commands, e-mail: users-help at mapguide.osgeo.org
http://www.nabble.com/Error%3A-Unable-to-Make-Permanent-Changes-to-Map-tf2482437s16610.html#a9135931
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
