[mapguide-users] Connecting to FDO Providers in MapGuide Studio
Andy Morsell amorsell at spatialgis.com
Mon Feb 26 12:09:06 EST 2007
A reinstallation of just the Server component, where the FDO providers live,
only takes a few minutes.  You can usually perform this install without
needing to reinstall and reconfigure the web extensions.  However, if you
have changed your repository paths, you will have to reset them or backup
and replace your C:\Program
Files\Autodesk\MapGuideEnterprise2007\Server\Bin\serverconfig.ini file.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Gary Ellsworth
Sent: Monday, February 26, 2007 4:49 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Connecting to FDO Providers in MapGuide Studio
I am using MapGuide Studio 2007 with Mapguide Open Source 1.1.0 server and
when I try to use the File> New > Data Connection in MapGuide Studio to
connect to the FDO Providers, I get an empty Data dialog box showing none of
the FDO Providers. Autodesk suggests that after installing the updated dlls,
which I have done, that I reinstall the server. Is there another solution or
change in configuration that would not require a complete reinstall? Any
suggestions on this would be greatly appreciated.
Thanks
Gary
Gary Ellsworth
GIS Manager/Regional Park Planner
Cleveland Metroparks
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070226/f580ec19/attachment.html
