[Mapguide_users] Coordinate Systems and Zooms
Andy Morsell amorsell at spatialgis.com
Wed Jan 3 12:49:36 EST 2007
 I have the same problem with a map in an international foot state plane
coordinate system (Oregon, South Zone, NAD83, International feet).  The same
thing occurs if you are using a custom web layout search command on a layer.
The search works (as long as its not on a joined field) but clicking on a
result zooms to 0,0 with  a scale of 1:0.001.
Andy
-----Original Message-----
[mailto:mapguide_users-bounces at lists.osgeo.org] On Behalf Of Scott Hameister
Sent: Tuesday, January 02, 2007 8:16 AM
To: mapguide_users at lists.osgeo.org
Subject: [Mapguide_users] Coordinate Systems and Zooms
I'm having trouble with Zooms in Authored Maps with Coordinate Systems
Assigned...Example I have a Lat/Lon WGS84 map Of states and Counties
Projected locally into UTM Zone 16N...I can look at a weblayout...select a
county...right click and do a zoom selected and it flys off into
nowheresville...It seems to be zooming to the Lat and Lon cords of the
county and not the UTM...is this a known bug, and is there a Fix for this?
Mapguide_users mailing list
Mapguide_users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide_users
More information about the Mapguide-users mailing list
