[Mapguide_users] KML files and Localhost
Chris Claydon
chris.claydon at autodesk.com
Thu Jan 4 12:54:35 EST 2007
Interesting. Are you using the latest Google Earth beta? I'm using
version 4.0.2416. MapGuide uses elements only supported by version 2.1
of the KML spec, and you need a fairly recent version of the GE beta for
it to work properly. I'm not sure what'll happen if you feed
MapGuide-generated KML into an old version of GE.
Chris.
_____
[mailto:mapguide_users-bounces at lists.osgeo.org] On Behalf Of Andy
Morsell
Sent: January 4, 2007 10:49 AM
To: mapguide_users at lists.osgeo.org
Subject: RE: [Mapguide_users] KML files and Localhost
No, I do not get a NetworkLinkControl element in my KML. The only
difference I can see between Scott's and mine is that I do not have any
CDATA tags in mine. I am using the only version of RC1 I have available
which is installed on Linux Fedora 4 from the latest tarballs last week.
I am also not using localhost.
I just realized that this the KML when saved from Google Earth. I saved
the KMZ from the GetMapKml request and extracted and looked at the KML
file. That one does contain the NetworkLinkControl element.
Andy
_____
From: Chris Claydon [mailto:chris.claydon at autodesk.com]
Sent: Thursday, January 04, 2007 9:30 AM
To: Andy Morsell; mapguide_users at lists.osgeo.org
Hi Andy,
If you issue a GetMapKml request, do you get a NetworkLinkControl
element near the top of the KML document? It should be there, but it's
not present in Scott's example. I have a suspicion that something in his
installation is out-of-date.
Scott,
Did you get my second email regarding the DLL versions yesterday?
Chris.
_____
Morsell
Sent: January 4, 2007 10:23 AM
Scott,
That screenshot shows the Sheboygan network link folder as turned off
and the error coming from your MyWeather map. Does Sheboygan work or
are all localhost GetMapKml and GetLayerKml requests not working? The
KML you included looks fine for the network link definitions.
Andy
_____
From: Scott Hameister [mailto:ScottH at mPower-tech.com]
Sent: Thursday, January 04, 2007 8:00 AM
To: 'Andy Morsell'
<kml xmlns="http://earth.google.com/kml/2.0">
<Document>
<name>Sheboygan</name>
<open>1</open>
<Region><LatLonAltBox><north>43.797520</north><south>43.691398</south><e
ast>-87.695522</east><west>-87.764987</west></LatLonAltBox></Region>
<NetworkLink>
<name>Roads</name>
<Url>
</Url>
<Link><href>http://localhost:80/mapguide/mapagent/mapagent.fcgi?OPERATIO
N=GetLayerKml<![CDATA[&VERSION=1]]><![CDATA[&LAYERDEFINITION=Library://S
amples/Sheboygan/Layers/Roads.LayerDefinition]]><![CDATA[&DRAWORDER=8]]>
<![CDATA[&FORMAT=KMZ]]><![CDATA[&SESSION=01ef0442-0000-1000-800b-00c09ff
d5d3f_en
]]></href><viewRefreshMode>onStop</viewRefreshMode><viewRefreshTime>1</v
iewRefreshTime><viewFormat>BBOX=[bboxWest],[bboxSouth],[bboxEast],[bboxN
orth]<![CDATA[&WIDTH=[horizPixels]]]><![CDATA[&HEIGHT=[vertPixels]]]></v
iewFormat></Link>
</NetworkLink>
<NetworkLink>
<name>Rail Lines</name>
<visibility>0</visibility>
<Url>
--------------------snip------------------------
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070104/11b1305e/attachment.html
More information about the Mapguide-users
