[Mapguide_users] RE: mapguide, php, and linux
Trevor Wekel trevor.wekel at autodesk.com
Wed Jan 10 12:57:13 EST 2007
Hi Kencana,
Some of the internal testing I am doing seems to indicate that Windows
may be faster for maps with large SDF data sets (gigabytes) and many
(90+) layers.
Others on the list are reporting different results so it may depend on
your dataset.
Thanks,
Trevor
-----Original Message-----
Sent: Tuesday, January 09, 2007 5:38 PM
To: Mapguide_users at lists.osgeo.org
Subject: Re: [Mapguide_users] RE: mapguide, php, and linux
Hi Trevor,Andy
Thanks for the explanation. can I know which will give better
performance?
linux or windows?
Thank you
Regards,
Kencana
Trevor Wekel wrote:
> Hi Kencana,
> Yes.  The PHP WebExtensions API is the same on Windows and Linux.  If
> your page / URL references are relative then you should be able to
> simply copy the code to Apache and package or copy the Server
> repositories to Linux.
> Thanks,
> Trevor
> _______________________________
> Hi all,
> as previously i done my code in php,windows server 2003, IIS, i was
> wondering if i migrate it to a linux server will it works?
> and instead of working with IIS, i was wondering mapguide will work on
> tomcat or apache in linux server.
> so, my plan is to migrate to a linux server using PHP,Tomcat or
apache?
> will everything works just like in windows server 2003?
> Regards,
> Kencana
> http://www.nabble.com/mapguide%2C-php%2C-and-linux-tf2943556.html#a823
> 10
> 50
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> Mapguide_users mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide_users
http://www.nabble.com/mapguide%2C-php%2C-and-linux-tf2943556.html#a82500
50
More information about the Mapguide-users mailing list
