[mapguide-users] buffer feature create. around added point.
    Maciej Skorczewski
    maciej.skorczewski at procad.pl
    Mon Jan 15 05:49:24 EST 2007
Hi!
I add some points to map  (code in PHP)
When point is created i want to create a buffer around this point...when
i make it i get this error.
--start error message---
1 layers were excluded from buffer computation because their coordinate
systems are incompatible with the coordinate system of the map, or
because they have no coordinate system at all
--end error message---
so where can i set valid coordinate system? My map use
- *XY-M* (Arbitrary X-Y Coordinates (Meters))-.
//Creating the point
// $x , $y come from database
$geometryFactory = new MgGeometryFactory();
$coordinate = $geometryFactory->CreateCoordinateXY($x,$y);
$point = $geometryFactory->CreatePoint($coordinate);
//Define a property collection
$geometryReaderWriter = new MgAgfReaderWriter();
$properties = new MgPropertyCollection();
$properties->Add(new MgInt32Property('Id_obiektu',''.$id.''));
$properties->Add(new MgStringProperty('Typ',''.$typ_obiektu.''));
$properties->Add(new MgGeometryProperty('SHPGEOM',
$geometryReaderWriter->Write($point)));
//Create an insert command for this property.
$parcelMarkerCommands->Add(new MgInsertFeatures('Obiekty', $properties));
if ($parcelMarkerCommands->GetCount() > 0)
          $featureService->UpdateFeatures($parcelMarkerFeatureSourceId,
$parcelMarkerCommands, false);
          $parcelMarkerLayer->SetVisible(true);
     $parcelMarkerLayer->SetName("Obiekty");
     $parcelMarkerLayer->SetLegendLabel("Obiekty");
     $parcelMarkerLayer->SetDisplayInLegend(true);
     $parcelMarkerLayer->SetSelectable(true);
          $parcelMarkerLayer->ForceRefresh();
          $sessionIdName = "Session:$mgSessionId//gdansk2.Map";
          $sessionResourceID = new MgResourceIdentifier($sessionIdName);
          $sessionResourceID->Validate();
          $map->Save($resourceService, $sessionResourceID);
          $mapUpdated = true;
else
Maciek
