[mapguide-users] buffer feature create. around added point.
Maciej Skorczewski maciej.skorczewski at procad.pl
Mon Jan 15 08:42:22 EST 2007
thx Walt!
i use it and it works great!
...the problem was with 2 different coordinate system.(map and script
who add new point)
take a look:
http://img270.imageshack.us/img270/3442/beztytu322uqe8.jpg
Maciek
Walt Welton-Lair napisał(a):
> A layer will be excluded from buffering if either one of these applies:
> 1) the map coordinate system is non-arbitrary and the layer coordinate
> system is arbitrary, or vice-versa
> 2) the layer and map coordinate systems are both arbitrary but have
> different units
> The layer's coordinate system comes from the feature source.  If your
> feature source CS is non-arbitrary then you'll need to set a
> non-arbitrary CS on the map to make this work.  Both MapGuide Studio and
> Web Studio let you do this.
> Walt
