[mapguide-users] Problem with Oracle Provider
Orest Halustchak
orest.halustchak at autodesk.com
Wed Jan 17 11:03:51 EST 2007
Hi Simone,
3D (xyz) data should be handled.
Could you provide a bit more information as to the data that you're
accessing. What is the information in user_sdo_geom_metadata for your
geometry column? What are the other column types in the table that
you're accessing?
Thanks,
Orest.
_____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Simone
MapGuide
Sent: Wednesday, January 17, 2007 9:42 AM
To: mapguide_users at lists.osgeo.org
Subject: [mapguide-users] Problem with Oracle Provider
Hello
I can't create a layer with this database. The error is: The featue
source is invalid. Reason: An unclassified exception ocurred. Although,
I can create a layer when I use a database with only 2 dimension(X,Y).
Is there some problem to access to Oracle provider with 3D database?
regards.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070117/962440c3/attachment.html
