[mapguide-users] MapGuide API - HTTP 500 Errors
Jason Birch
Jason.Birch at nanaimo.ca
Thu Jan 18 11:57:38 EST 2007
What version are you running?
There have been some issues with the fastcgi app that give this kind of
response.
I've found that this behaviour is limited by setting certain registry
settings (have to go but will check later).
You can also take fastcgi out of the loop, but it's slower that way.
Jason
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Knight,
Gregory
Sent: Thursday, January 18, 2007 08:52
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] MapGuide API - HTTP 500 Errors
Hi all,
I am experiencing some strange behavior with a web service I have
developed that hits the MapGuide API.
I have deployed an MGOS application developed in .Net that utilizes the
AJAX viewer.
I have also deployed a web service (also in ..Net) that exposes a
specific portion of the functionality contained in the full-blown
application.
If the application has been idle for some time (as in not getting any
hits), and I hit the web service, I get HTTP 500 errors. When I get the
500 error, if I hit the MapGuide application, then try the web service
again, the 500 error goes away and the web service behaves properly.
Any clue what might be going on here?
Thanks,
Greg
The substance of this message, including any attachments, may be
confidential, legally
privileged and/or exempt from disclosure pursuant to Massachusetts
law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and
delete the material from any computer.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070118/da86f234/attachment.html
