[mapguide-users] MapGuide Open Source 1.1.0 Released
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Tue Jan 23 12:20:05 EST 2007
Ok, thanks for the clarification Tom.
Andrew
Tom Fukushima wrote:
> Hi Andrew,
> For the windows installers all of the open source FDO providers listed
> at http://fdo.osgeo.org (except for the OGR provider*) are installed
> when the server is installed. The source for the Linux versions can
> be found at http://fdo.osgeo.org/downloads.html.
> * The OGR Provider is not included because there is no Linux version
> for it. We will be shortly posting the compiled binary FDO 3.2
> version of it for download as before for those who would like it.
> Hi Chris,
> It looks as if your install of the server may be corrupt; there should
> not be any duplicates in the "Connect to Data" dialog. I'm not sure
> how to resolve this, but a clean install (make sure to save your
> repositories) of the server may be required.
> Were you able to get rasters to display in MGOS 1.1.0RC1 and are
> finding that they are no longer displayed in MGOS 1.1.0?
> I'm not sure how you are getting rasters onto the server, but it is
> not possible to use a Studio load procedure to load rasters onto MGOS
> 1.1.0. The Studio load procedure for rasters requires that the server
> have the Autodesk Raster Provider installed. To create raster data
> sources in Studio using the GDAL provider, do a File > New Data
> Connection... and select "OSGeo FDO Provider for Raster". Then enter
> the directory where the rasters are located in the
> "DefaultRasterFileLocation" connection property. Leave all other
> fields unchanged.
> Of course a clean install may resolve your raster problems as well.
> Tom
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Chris
> Tallman
> *Sent:* Tuesday, January 23, 2007 8:03 AM
> *To:* Andrew DeMerchant; mapguide-users at lists.osgeo.org
> *Subject:* RE: [mapguide-users] MapGuide Open Source 1.1.0 Released
> I may be wrong or maybe this is part of my problem too, but I think
> the new FDO's are installed with the update. However the raster FDO
> or GDAL driver doesn't seem to be working correctly. I get this error
> after loading aerials.
> I've checked my providers.xml and this txt is included.
> <FeatureProvider>
> * * <Name>*OSGeo.Gdal.3.2*</Name>
> * * <DisplayName>*OSGeo FDO Provider for Raster*</DisplayName>
> * * <Description>*Read access to various raster-based file formats.
> Supports georeferenced file-based raster images.*</Description>
> * * <IsManaged>*False*</IsManaged>
> * * <Version>*3.2.0.0*</Version>
> * * <FeatureDataObjectsVersion>*3.2.0.0*</FeatureDataObjectsVersion>
> * * <LibraryPath>*E:\Program
> Files\MapGuideOpenSource\Server\Bin\FDO\GRFPProvider.dll*</LibraryPath>
> </FeatureProvider>
> The GRFPProvider.dll exists in the correct folder.
> Also all the FDO providers are doubled in the list, again a check the
> providers.xml file and both 3.1 and 3.2 providers were in the file so
> I removed the 3.1, however I still see two of each provider.
> Any ideas?? Did I miss something with the new install?
> Chris
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Andrew
> DeMerchant
> *Sent:* Tuesday, January 23, 2007 9:50 AM
> *To:* mapguide-users at lists.osgeo.org
> *Subject:* Re: [mapguide-users] MapGuide Open Source 1.1.0 Released
> Am I blind, or is there no longer a place to download the FDO from the
> MapGuide site? I can't even find a place to download the compiled FDO
> from the FDO site!
> Andrew
>> The MapGuide Open Source developers and project steering committee
>> are pleased to announce the release of MapGuide Open Source 1.1.0.
>> This release contains many bug fixes as well as the following notable
>> enhancements:
>> * FDO 3.2 API support - MapGuide now supports the latest FDO API
>> * Direct KML support - allows layers styled in MapGuide to be
>> displayed as layers in Google Earth
>> Details of all enhancements and defect fixes are described at
>> _http://download.osgeo.org/mapguide/releases/1.1.0/ReleaseNotesMapGuideOpenSource-1.1.0.html_.
>> The new release can be downloaded from
>> _http://mapguide.osgeo.org/downloads.html_.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
