[mapguide-users] RE: MapGuide Open Source 1.1.0 Released
Webo vedad at sl-king.com
Wed Jan 24 03:04:59 EST 2007
Hello Tom,
I was allready posting about the problem with rasters (GDAL). This is what I
get:
I am running MGOS 1.1.0, MGStudio 2007, Oracle 10gR2 on WinXP SP2. I am
using King.Oracle provider 0.5.1 and it works fine. I have few layers with
different data from Oracle, sdf  and shp files.
To add raster image (TIF) I used NEW->Data Connection->OSGeo FDO Provider
for Raster, then I selected a folder where my raster images are and added
these TIF files. Then I made layer using this Data source and added the
layer to Map. I also have a web layout which uses this Map.
I can see raster in the Map (definition) but not properly. If I have e.g. 4
TIF files in my default raster folder, in a Map definition (or Web layout) I
see only 1 TIF file stretched over the screen and it is deforming when I use
pan view tool.
I think think this is a real problem, but I hope there is solution :)
Best regards,
Webo
I also tried to add rasters using New->Load Procedure (or drag and drop from
win explorer to Site explorer (MGStudio) but I get Warninh message: "Server
does not support requested provider: Autodesk.Raster"
Tom Fukushima wrote:
> Hi Chris,
> The layer preview won't show anything because the raster provider
> doesn't return the bounding box for the image and so Studio isn't able
> to determine what area to show in the preview.  (This issue can be
> resolved in Studio by using other methods to get the bounding box of the
> features, but it has not been incorporated yet.)
> In the meantime, try creating a map definition, add the raster layer,
> then manually set the extents of the map to envelop the data.  Then if
> you preview the map definition, you should be able to see the raster.
> I don't know of an online help file for using GDAL. I'll try to put a
> wiki page together on this for what I know about this when I get some
> time.
> Tom
>   _____
> From: Chris Tallman [mailto:ctallman at innomap.com]
> Sent: Tuesday, January 23, 2007 11:00 AM
> To: Tom Fukushima; mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] MapGuide Open Source 1.1.0 Released
> Tom,
> I was trying to use a LP, I never updated to RC1 so I didn't get a crack
> at using it.
> I did as you suggested, connected to the folder location that stores the
> images, which I must say is a better way to connect to the images.  From
> there I created a layer based on this data connection.  However I still
> am not getting images, I am trying to connect to tif files since Sid's
> are not supported at this time.  When I click test connection it's
> successful, so I can't figure out why no aerials are showing up.  My
> aerials are in the same coordinate system as my map if that's a factor.
> Do the images have to be on the same computer as MGOS?
> I looked at the help file and the was useless as I didn't see anything
> about using the gdal, is there a help file online some place?
> Chris
>   _____
> From: Tom Fukushima [mailto:tom.fukushima at autodesk.com]
> Sent: Tuesday, January 23, 2007 12:17 PM
> To: Chris Tallman; Andrew DeMerchant; mapguide-users at lists.osgeo.org
> Hi Andrew,
> For the windows installers all of the open source FDO providers listed
> at http://fdo.osgeo.org (except for the OGR provider*) are installed
> when the server is installed.  The source for the Linux versions can be
> found at http://fdo.osgeo.org/downloads.html.
> * The OGR Provider is not included because there is no Linux version for
> it.  We will be shortly posting the compiled binary FDO 3.2 version of
> it for download as before for those who would like it.
> Hi Chris,
> It looks as if your install of the server may be corrupt; there should
> not be any duplicates in the "Connect to Data" dialog. I'm not sure how
> to resolve this, but a clean install (make sure to save your
> repositories) of the server may be required.
> Were you able to get rasters to display in MGOS 1.1.0RC1 and are finding
> that they are no longer displayed in MGOS 1.1.0?
> I'm not sure how you are getting rasters onto the server, but it is not
> possible to use a Studio load procedure to load rasters onto MGOS 1.1.0.
> The Studio load procedure for rasters requires that the server have the
> Autodesk Raster Provider installed.  To create raster data sources in
> Studio using the GDAL provider, do a File > New Data Connection... and
> select "OSGeo FDO Provider for Raster".  Then enter the directory where
> the rasters are located in the "DefaultRasterFileLocation" connection
> property. Leave all other fields unchanged.
> Of course a clean install may resolve your raster problems as well.
> Tom
>   _____
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris
> Tallman
> Sent: Tuesday, January 23, 2007 8:03 AM
> To: Andrew DeMerchant; mapguide-users at lists.osgeo.org
> I may be wrong or maybe this is part of my problem too, but I think the
> new FDO's are installed with the update.  However the raster FDO or GDAL
> driver doesn't seem to be working correctly.  I get this error after
> loading aerials.
>  I've checked my providers.xml and this txt is included.
> <FeatureProvider>
>   <Name>OSGeo.Gdal.3.2</Name>
>   <DisplayName>OSGeo FDO Provider for Raster</DisplayName>
>   <Description>Read access to various raster-based file formats.
> Supports georeferenced file-based raster images.</Description>
>   <IsManaged>False</IsManaged>
>   <Version>3.2.0.0</Version>
>   <FeatureDataObjectsVersion>3.2.0.0</FeatureDataObjectsVersion>
>   <LibraryPath>E:\Program
> Files\MapGuideOpenSource\Server\Bin\FDO\GRFPProvider.dll</LibraryPath>
> </FeatureProvider>
> The GRFPProvider.dll exists in the correct folder.
> Also all the FDO providers are doubled in the list, again a check the
> providers.xml file and both 3.1 and 3.2 providers were in the file so I
> removed the 3.1, however I still see two of each provider.
> Any ideas??  Did I miss something with the new install?
> Chris
>   _____
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andrew
> DeMerchant
> Sent: Tuesday, January 23, 2007 9:50 AM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] MapGuide Open Source 1.1.0 Released
> Am I blind, or is there no longer a place to download the FDO from the
> MapGuide site? I can't even find a place to download the compiled FDO
> from the FDO site!
> Andrew
> 	The MapGuide Open Source developers and project steering
> committee are pleased to announce the release of MapGuide Open Source
> 1.1.0.  This release contains many bug fixes as well as the following
> notable enhancements:
> 	* FDO 3.2 API support - MapGuide now supports the latest FDO API
> 	* Direct KML support - allows layers styled in MapGuide to be
> displayed as layers in Google Earth
> 	Details of all enhancements and defect fixes are described at
> http://download.osgeo.org/mapguide/releases/1.1.0/ReleaseNotesMapGuideOp
> enSource-1.1.0.html
> <http://download.osgeo.org/mapguide/releases/1.1.0/ReleaseNotesMapGuideO
> penSource-1.1.0.html> .
> 	The new release can be downloaded from
> http://mapguide.osgeo.org/downloads.html
> <http://mapguide.osgeo.org/downloads.html> .
>   _____
> 	_______________________________________________
> 	mapguide-users mailing list
> 	http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Andrew DeMerchant
> Computer Technologist
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> GEMTEC Limited <http://www.gemtec.ca>
> 191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
View this message in context: http://www.nabble.com/MapGuide-Open-Source-1.1.0-Released-tf3060279s16610.html#a8556385
