[mapguide-users] Raster in MapGuide Hand Holding
Nichols, Mark A. markn at spicergroup.com
Thu Jan 25 08:51:28 EST 2007
I'm still having problems.  Here's the steps I've taken.
1.  Using the Windows installers, I've installed the current release 1.1.0.  Both the server and the extensions.
2.  I've installed MapGuide Studio and applied the patch.  There's a SP for Studio and I've applied that as well.
3.  I've tried a lot of different things at this point to get a raster in but haven't been successful.  If you would be so kind, could you please tell me what your next step would be.
I want to make sure that I'm loading rasters correctly.  It doesn't matter to me if I use Studio if there's another way to do it.
Thanks.
Mark Nichols
From: mapguide-users-bounces at lists.osgeo.org on behalf of Frank Warmerdam
Sent: Thu 1/25/2007 8:12 AM
To: Webo
Cc: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Raster in MapGuide Hand Holding
Webo wrote:
> Hello Frank,
> I've been working with MapGuide for a while, and as you know I had some
> similar problems with rasters.
> When I make Data Connection using GDAL provider and a layer with that data
> source (raster Connection), I can't see raster in the layer preview. When I
> add this layer to may Map I see it but not properly (just one random TIF
> file from my raaster folder stretched over the screen).
Webo,
Note that the stretching problem is an old bug that was accidentally
included in the MapGuide OS 1.1.0 for windows release build.  Greg Boone
has prepared a fixed build of the provider that can be overlaid on
the 1.1.0 release to resolve this issue.
> To see your Map in browser you have to make Web layout and use your Map
> Definition in the "Map resource used in this layout" field. Then you click
> "Go" button beside "Preview in browser using..." in the Web layout window.
Yes, TomF walked me through this yesterday.
I also went through the process of building an ECW plugin for GDAL 1.3.1
for MapGuide for I haven't yet succeeded in getting it to work in
MapGuide.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
