[mapguide-users] 1.1.0 and WFS?
Jason Birch
Jason.Birch at nanaimo.ca
Thu Jan 25 13:10:55 EST 2007
I have an install of MGOS 1.1.0 running on Windows XP (as a bundled
config, not IIS) and it is responding with a proper capabilities
document to:
http://jesse/mapguide/mapagent/mapagent.fcgi?request=GetCapabilities&ser
vice=WFS&version=1.0.0
I see a schema for 1.1.0 in the install, but a request for 1.1.0
responds with the 1.0.0 capabilities doc, so I don't think the VERSION
parameter is being honoured. Is this correct behaviour (responding with
a downgraded capabilities document when a higher version is requested)?
Andy, do you have any other FDO apps installed on that server?
Jason
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy
Morsell
Sent: Thursday, January 25, 2007 09:52
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] 1.1.0 and WFS?
Autodesk, can you confirm that you can successfully test WFS on a
default 1.1.0 Windows install via the following URL?
http://servername/mapguide/mapagent/mapagent.fcgi?request=getCapabilitie
s&se
rvice=wfs&version=1.0.0
Andy
Sent: Thursday, January 25, 2007 9:41 AM
To: Andy Morsell
The problem doesn't seem to be a dependency problem.
The "Provider Not Registered" message means that the provider name is
not found in the providers.xml file.
Are you sure you are looking at the correct providers.xml file?
