[mapguide-users] Listing Active selected feature C#
Andy Morsell amorsell at spatialgis.com
Fri Jan 26 18:31:34 EST 2007
That's a URL encoded equivalent of the XML string.  I'm not sure what you
are doing with the XML after getting it, but take a look at the
HttpUtility.UrlDecode method in the .NET framework (it's in the System.Web
assembly) for details on how to decode the string.
Andy
  _____
From: Nimrod Cnaan [mailto:nimcnaan at hotmail.com]
Sent: Friday, January 26, 2007 3:03 PM
To: amorsell at spatialgis.com
Subject: RE: [mapguide-users] Listing Active selected feature C#
Hi Andy & thank you both - Please let me know if you know anything about
this:
It seems that my problem with 'listing selected feature' is not a
programming issue rather then something to do with my environment, or I'm
getting it all wrong.
When Invoking URL, I'm getting the selected features under the following
string, witch is not a known XML format (getting strange xml characters):
[%3C%3Fxml%20version%3D%221.0%22%20encoding%3D%22UTF-8%22%3F%3E%0A%3CFeature
Set%3E%0A%3CLayer%20id..] Act'.
Then getting an unclassified error exception occurred. "An unclassified
exception occurred. Exception occurred in method MgSelection.FromXml at line
158 in file
c:\build_tux_area\mgdev_opensource\common\service\maplayer\Selection.cpp"
Strangely, When Invoking Script commands on selected featur I get things OK.
<FeatureSet>
<Layer id="0fa0e9e4-0000-1000-8002-0018de8d1ec0">
<Class id="Default:Helkot">
<ID>KwAAAA==</ID>
</Class>
</Layer>
</FeatureSet>
  _____
To:  <mapguide-users at lists.osgeo.org>
Date:  Sun, 21 Jan 2007 11:14:39 -0800
Greg,
Would it be possible for you to post the example to the
group?  The list should accept plain text file attachments or you could
paste it into the message body.
Andy
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Knight,
Gregory
Sent: Sunday, January 21, 2007 10:43 AM
To: Nimrod
Cnaan; mapguide-users at lists.osgeo.org
I have a C# example where I
am doing exactly this. I can send you the page via separate means if you are
interested.
Greg
  _____
behalf of Nimrod Cnaan
Sent: Sat 1/20/2007 9:13 AM
To:
Subject: [mapguide-users] Listing
I am attempting to get the list of selected parcels by using
"Invoke URL"
command, passing "$Current Selection" to my
"listdwfparcels.aspx" page,
through the key & value pair.
I don't
know what I'm doing wrong, getting unclassified
exception
"MgSelection.FromXml" . . .
Checking the value of my mgkey
content "$Current Selection"
returns:
%3C%3Fxml%20version%3D%221.0%22%20encoding%3D%22UTF-8%22%3F%3E%0A%3CFeatureS
et%3E%0A%3CLayer%20id%3D%22d6a8101a-ffff-ffff-8003-000000000038%22%3E%0A%3CC
lass%20id%3D%22Default%3AHelkot%22%3E%0A%3CID%3ETAAAAA%3D%3D%3C%2FID%3E%0A%3
CID%3EVwAAAA%3D%3D%3C%2FID%3E%0A%3CID%3EVgAAAA%3D%3D%3C%2FID%3E%0A%3C%2FClas
s%3E%0A%3C%2FLayer%3E%0A%3C%2FFeatureSet%3E%0A
Here
is portion of the code that I'm using -
String mgSessionId =
GetParameters()["SESSION"];
String mgSelection =
GetParameters()["mgkey"];
MgResourceIdentifier
layerFeatureResource;
MgReadOnlyLayerCollection layers;
MgSelection
selection;
MgLayer layer;
string layerClassName;
string
selectionString;
string
layerFeatureId;
 try
  InitializeWebTier();
  MgUserInformation userInfo = new
MgUserInformation(mgSessionId);
  MgSiteConnection siteConnection = new
MgSiteConnection();
  siteConnection.Open(userInfo);
MgResourceService resourceService
siteConnection.CreateService(MgServiceType.ResourceService)
as
MgResourceService;
  MgFeatureService featureService
siteConnection.CreateService(MgServiceType.FeatureService)
as
MgFeatureService;
  MgFeatureQueryOptions queryOptions = new
MgFeatureQueryOptions();
  MgMap map = new
MgMap();
  map.Open(resourceService, "HaifaMap");
if
(GetParameters()["SESSION"] != "")
    selection = new
MgSelection(map, mgSelection);
<<<<< MY ERROR
An unclassified exception occurred.An unclassified
exception occurred.
158 in
file
Nimrod
Cnaan - GIS Senior Programmer
Haifa Municipality,
Israel
Phon:972525355483
View this message in context:
http://www.nabble.com/Listing-Active-selected-feature-C--tf3045397s16610.htm
l#a8465318
Sent
from the MapGuide Users mailing list archive at
Nabble.com.
mapguide-users
http://lists.osgeo.org/mailman/listinfo/mapguide-users
  _____
The substance of this message, including any attachments, may
be
confidential, legally
privileged and/or exempt from disclosure pursuant
to Massachusetts
law. It is intended
solely for the addressee. If you
received this in error, please
contact the sender and
delete the material
from any computer.
>_______________________________________________
>mapguide-users mailing list
  _____
Express yourself instantly with MSN Messenger! MSN Messenger
<http://g.msn.com/8HMBEN/2743??PS=47575>  Download today it's FREE!
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070126/2d2f8a6c/attachment-0001.html
