[mapguide-users] MapGuide 1.0.2 memory leak?
Martin Fafard
martin.fafard at geoprojection.com
Sun Jan 28 17:46:06 EST 2007
FDO 3.2 improve sdf and shp better than 3.0? Could it be a fastcgi
problem? I have the same problem: very slom after 5 minutes (10 zoom or
pan) (bundle Apache is installed).
Martin Fafard
Zak James a écrit :
> Julien,
> I'm not sure we saw that kind of memory leak, but we weren't hitting
> 1.0.2 that hard. The 1.1.0 release is definitely worth upgrading to if
> for no other reason than it uses fdo 3.2 which includes new and
> improved providers.
> zak
> On 1/27/07, Julien-Samuel Lacroix <jlacroix at mapgears.com> wrote:
>> Hi,
>> We got a MapGuide 1.0.2 installation running under Apache on a Windows
>> 2003 server that got some memory problem. The application is using the
>> ajax viewer. It is live and running well normally. But after a day or
>> two, the application becomes slow and a simple zoom-in uses 100% of the
>> CPU and it takes a while to redraw the map.
>> Does anybody encounter a simmilar behavior?
>> Is there any bug fixes in 1.1.0 that may worth an upgrade to 1.1.0?
>> Thanks
>> Julien
>> Mapgears
>> http://www.mapgears.com/
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
