[mapguide-users] does not print Map image with IE 7.0
Vaidas Velutis vaidas at infoera.lt
Tue Jan 30 10:03:28 EST 2007
I use ajax viewer, but i think you misunderstand my problem, first i call
biult in command print 'get printable page' and then i try to print that
page. there is map image in that printable page which does not print even if
i click 'print image...'.
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris Gountanis
Sent: Tuesday, January 30, 2007 4:45 PM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] does not print Map image with IE 7.0
Sounds to me you are not getting the right click context menu that is built
into the viewer. Are you using the ajax viewer or dwf? It might be possible
when you right click to get picture it is some kind of transparent overlay.
Chris
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Vaidas Velutis
Sent: Tuesday, January 30, 2007 8:45 AM
To: mapguide-users at lists.osgeo.org
right click and then select 'print picture...' then printer prints nothing
at all:)
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
Sent: Tuesday, January 30, 2007 4:17 PM
Try a right click on the map?
  _____
Sent: Tuesday, January 30, 2007 3:09 AM
Subject: [mapguide-users] does not print Map image with IE 7.0
Hi,when i try to print map it only prints map name and arrow (image of the
map leaves blank on the paper). with I.E 6.0 everything is ok, so i think it
is some option that disables image printing in IE 7.0. i`ve found in
internet options such thing "print background colors and images" (advanced
tab) and checked it but it wont worked. Maybye someone know where is the
clue?
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070130/06f21a06/attachment-0001.html
