[mapguide-users] PostGIS - what is wrong whit that? - my todo list
Traian Stanev
traian.stanev at autodesk.com
Wed Jan 31 10:25:24 EST 2007
The first thing you can try is -- instead of previewing the layer,
create a map and add the layer to it. Then set the map extents to the
known extents of the data. This will eliminate any extents reporting
issues and narrow down the problem. I will download your data and take a
look at it whenever I get a chance. By the way, when I tested the OGR
provider with PostGIS, I did the exact same thing as you -- converted
from SHP to sql and executed against PostGIS to get some data into it.
Traian
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Maciej
Skorczewski
Sent: Wednesday, January 31, 2007 7:54 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] PostGIS - what is wrong whit that? - my todo
list
Hi!
I try to show layer who is stored in Postgresql Database (whit PostGis)
Pleas check what i make wrong:
______________________
1. I convert shp file:
-> shp2pgsql input_shape_file.shp table_name > output.sql
2. i put in into database
-> psql -U postgresql -d database_name -f output.sql
3. I use Studio to create a Data Connection
i use OSGeo.OGR ,
connection string :
PG: host=localhost user=postgres dbname=postgis password=passw
...when i check data connection all is OK (Successful connection.)
4. then i create a layer
(it is comes form Studio)
Data resorce: Library://test/postgis.FeatureSource
Feature Data Setup
Feature class: ORGSchema:siec
Geometry: the_geom (? i think that it is error or bad. what sould?)
after that i don't see anything (blank screen)
so what is wrong?
in this url are zip archive whit my files. take a look.
http://easy3249.easyisp.pl/siec.zip
maciek
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
